Need some soldering tips - Never done it before... - Jemsite
post #1 of 11 (permalink) Old 11-30-2001, 01:17 PM Thread Starter
Hey everyone, need a little help...
I have a mono/stereo jack plate to install in my recto cab and need to solder the new wires from the jack plate to the speaker terminals. *I have zero experience with soldering of any kind, much less soldering electrical contacts.
What is the best technique for insuring good quality soldering? *Do I heat the wire with the iron then simultaneously place the wire and solder together on the contact terminal, or do I heat the terminal first or both? *or am I totally off base.
Thanks in advance.
Gresh is offline
post #2 of 11 (permalink) Old 11-30-2001, 03:54 PM
You can :read: *up on it here and also here.
Project Guitar is offline
post #3 of 11 (permalink) Old 11-30-2001, 04:07 PM
Good links Brian..
I find it comical that the 2 links you provided *seem to contadict each other in at least one area LOL
:biggrin:
vwall is offline
post #4 of 11 (permalink) Old 11-30-2001, 04:21 PM
Just like Ice cream everyone has a different flavor for doing something on their own =o)
post #5 of 11 (permalink) Old 11-30-2001, 04:25 PM
LOL!!!
The thing that stuck out the most was 1 said DO NOT put solder on the and the other says
Step 4 "Apply a very small amount of solder to the tip of the iron"
LOL
i thought it was hillarious in a *logistics kinda way
vwall is offline
post #6 of 11 (permalink) Old 11-30-2001, 04:38 PM
site founder 0% owner
jemsite's Avatar
those are a tough read (better photos would speak 10,000 words) but i think they both meant to prime the iron/lead with light amounts of solder before applying the actual solder over the joint... glen
jemsite is offline
post #7 of 11 (permalink) Old 11-30-2001, 04:47 PM Thread Starter
I think I get the idea. *I do some practice runs first. *Thanks for the help. *More pictures would have definitely been better for those sites.
Thanks
Gresh is offline
post #8 of 11 (permalink) Old 11-30-2001, 05:20 PM
Always *tin* the wires, the connection, and the tip of the iron. The melted solder on the iron will transfer heat so much faster to the joint than a dry iron will.
Rich is offline
post #9 of 11 (permalink) Old 11-30-2001, 05:47 PM
I remember my first attempt at soldering something...
I wanted to solder a new plug to a power supply and my father had a huge 150W soldering iron that should be used for industrial purposes. The tip of it was 1/2" and as soon as I tried to solder the plug it was completely covered with solder.
Bad idea, at least I learned that you should have a small iron for small things
SalemB is offline
post #10 of 11 (permalink) Old 11-30-2001, 06:05 PM
Rich/Glen
right on.
I was merely pointing out the idiosyncrasy of the two.
vwall is offline
post #11 of 11 (permalink) Old 12-01-2001, 01:34 AM
Well just like anything else it's best to have a couple of piece's of wire to practice on to get the real feel in this case. Yes I agree about the photo part. Maybe that will be another tutorial for my site some day....
jack plate , recto cab
Tips For Soldering. eyebahnez Tech: Setup, Repairs and Mods 12 06-28-2011 02:45 AM
I've been doing a lot of soldering Riverdragon All Other Guitars (including Prestige) 3 09-22-2009 12:09 PM
Tips for soldering the wire to the lug. Mario5150 Pickups & wiring 5 10-24-2007 12:59 PM
Soldering: What do I need? guitarman13 Tech: Setup, Repairs and Mods 10 05-16-2007 08:47 AM
I suck at soldering!!! - any tips or instructions?...please? oop Tech: Setup, Repairs and Mods 10 06-04-2001 04:30 PM
