noisy switch and pot - Jemsite
post #1 of 8 (permalink) Old 08-13-2011, 06:38 PM Thread Starter
Hi two of my older guitars are a bit "static" noisey one on the pickup selector switch and one on the volume dial.
Do I need to replace these components? or just get some kind of electrical contact cleaner in there and work it in a bit?
Thanks,
Phil
philster_d is offline
post #2 of 8 (permalink) Old 08-13-2011, 06:55 PM
Reviews: 98
Re: noisy switch and pot
Try the contact cleaner first. If that doesn't solve the problem--change out the switch and pot.
AlaskaBat is offline
post #3 of 8 (permalink) Old 08-13-2011, 11:57 PM
RGTFanatic's Avatar
This^^^^ contact cleaner should do nicely. If not, switches and pots are cheap..... they also give you an excellent reason to tear you guitar apart for a thorough cleaning
RGTFanatic is offline
post #4 of 8 (permalink) Old 08-14-2011, 06:42 AM Thread Starter
Thanks, the switch is on my les paul so it seems easily sprayed its pretty open. Ill look out for the right stuff to use.
Phil
post #5 of 8 (permalink) Old 11-08-2011, 03:06 AM
CAIG Deoxit
jasondmckay is offline
post #6 of 8 (permalink) Old 11-08-2011, 04:24 AM
just out of interest (coz im gonna be doing a similar thing soon!) do you just spray contact cleaner on and leave it and its done, or do you spray it on then use an old toothbrish or similar?
rickybaby1985 is offline
post #7 of 8 (permalink) Old 11-08-2011, 07:02 AM
Spray it and let it set a few seconds then work the control back and forth several times. Spray it again and repeat. Then let it dry out before you plug it back up and try it out.
gideond is offline
post #8 of 8 (permalink) Old 11-08-2011, 12:20 PM
I agree with gideond, however, I've never let any electronics dry out before using and I've never had any problems. Most cleaners have something similar to alcohol or have alcohol in them and it dries rather quickly.
If you have a tech nearby, they should do this for free for you. It only takes a minute or two.
electrical
Just how noisy are your pick ups? Freedom777 Pickups & wiring 13 06-01-2008 05:10 PM
Is your wah noisy? Rotti Gear, Equipment, Recording & Off Topic 20 04-09-2007 06:55 PM
Noisy pots Joe Satrini Ibanez JEM, UV, JS & Other Signature Models 13 10-16-2006 05:25 PM
Noisy Wah. Gex Gear, Equipment, Recording & Off Topic 0 11-29-2005 11:43 PM
amp noisy - when in switcher one less than none Gear, Equipment, Recording & Off Topic 5 10-10-2001 10:50 AM
