Not clear sound from the low strings in my JEM7V - Jemsite
post #1 of 6 (permalink) Old 01-10-2006, 07:46 AM Thread Starter
Hi all! I am a new member here. I would like to have some advice on a problem I have since I first bought my JEM7V. The problem persists even after the detailed setup that I did following the instruction found on this site. Needless to say the problem also persists no matter how new or of what brand the strings are.
After this long introduction, let me describe the situation. When fretting the low-E string above say the 15th fret the sound is not clear but instead sounds like there is some harmonic superimposed on the actual note. This also happens at the A string in a smaller degree, in the D string in even smaller and from the G string the sound is absolutely clear.
This resonance-like sound is heard both on the unplugged guitar but is also prominent through the amplifier when being plugged. With distortion I get a slowly oscillating sound, say with a period of 1/4 second. It is as if I am pressing-pulling the tremolo bar at that frequency while playing the note.
Hope you understand my problem and give me a solution.
Just note that the setup is perfect otherwise with no other problems. All of the parts seem to be in perfect condition too.
Any suggestions?
Thanks and regards ;-)
corinos is offline
post #2 of 6 (permalink) Old 01-11-2006, 02:11 AM Thread Starter
Re: Not clear sound from the low strings in my JEM7V
No reply???
Doesn't anybody have any clue?
Has this problem only occured to me?...
Help please.....!
corinos is offline
post #3 of 6 (permalink) Old 01-11-2006, 05:53 AM
Have you tried lowering the pickup involved?
Ibateur is offline
post #4 of 6 (permalink) Old 01-11-2006, 09:28 AM Thread Starter
Hmmm, I have not tried that. The sound that I describe is also heard with the guitar unplugged.
Maybe it is the force of the magnetic field that pulls the strings and damps them in a strange way?
I'll try that and get back.
corinos is offline
post #5 of 6 (permalink) Old 01-12-2006, 02:21 AM Thread Starter
Hey, thank you for your help Ibateur!
I lowered the pickups and indeed the muddled sound was reduced to a minimum.
It seems that I had overdone it in order to have hot signal.
Thanks again! ;-)
corinos is offline
post #6 of 6 (permalink) Old 01-12-2006, 09:08 AM
Cheers mate.
Ibateur is offline
tremolo bar
Edge Pro JEM7V 10 gauge strings change cpelaez Tech: Setup, Repairs and Mods 6 10-05-2012 11:28 AM
Oiling Fretboard - remove all strings, some strings, or no strings? Inzane Tech: Setup, Repairs and Mods 9 04-02-2012 08:40 AM
Ebony JEM7V VS. Rosewood JEM7V f'boards Mario5150 Ibanez JEM, UV, JS & Other Signature Models 9 07-09-2007 11:33 PM
Getting desperate... which bridge humbucker into a strat for clear, full sound... saTa Pickups & wiring 13 12-31-2005 02:48 AM
What does a clear (crystal planet) JS sound like? zerolight Ibanez JEM, UV, JS & Other Signature Models 5 03-24-2003 07:49 AM
