Notes detuning the moment i lock the locking nuts..pls help.. - Jemsite
post #1 of 10 (permalink) Old 12-23-2005, 11:36 AM Thread Starter
whenever i locked the nut down on the strings, the low E, A and D strings goes sharp..and the G, B and low E goes flat..i read the setup from this site, and adjusted the retaining bar, my strings are all seated on the gooves, but the problem is still happening, i removed the nuts, played it, and the strings are all in tune, the onli problem is that the strings go out the moment i lock them..i'm using an Edge trem..please help..thanks
kelvin55 is offline
post #2 of 10 (permalink) Old 12-23-2005, 11:40 AM
JJEMMER777's Avatar
Re: Notes detuning the moment i lock the locking nuts..pls help..
You do have to fine tune using the fine-tunners on the trem after you lock down.....you know this right?
JJEMMER777 is offline
post #3 of 10 (permalink) Old 12-23-2005, 11:45 AM Thread Starter
Red face Re: Notes detuning the moment i lock the locking nuts..pls help..
uhm, so it's the case that the fine tuning has to be used inevitably after locking down? anyway, it's virtually impossible to NOT use the fine tuners? i'm still new with dbl locking trems though..so i dun know alot of stuff..
kelvin55 is offline
post #4 of 10 (permalink) Old 12-23-2005, 11:55 AM
JJEMMER777's Avatar
Yeah - I just tune close to, but not right on and then lock down because when you lock down it pulls the strings tighter. Also, make sure you have plenty of lee-way in the fine tunners. Keep them backed out about 3/4 of the way before you lock down. Then you should be fine
post #5 of 10 (permalink) Old 12-23-2005, 11:58 AM Thread Starter
ahhhhhh....ok, so it's an approximation at the end of the day? well, i got it fixed, following ur advice! thanks a mil!
kelvin55 is offline
post #6 of 10 (permalink) Old 12-23-2005, 12:03 PM
JJEMMER777's Avatar
No probs man...glad to help Anytime you need advice come to this forum.....there are loads of brilliant Jemsters here that will not hesitate to help.
post #7 of 10 (permalink) Old 12-24-2005, 11:46 AM
I will add that when I have the guitar completely unlocked at the nut that I usually tune the low E and A then lock down that part of the nut. I do the same for the D and G, then the B and E. I have found that this helps. Esspecially with the fine tunners lee-way.
Earthrug is offline
post #8 of 10 (permalink) Old 12-24-2005, 06:18 PM
Talking Re: Notes detuning the moment i lock the locking nuts..pls help..
I do it the same way as Earthrug, but i find it even easier leaving the back plate off as you play your 6 week old rusted strings for the last time. Then block the trem and change your strings and tune them as close to n lock the nut and fine tune. After that get someone to hold the trem so the strings are quite sharp, then add the springs you took out for wood blocks, then get your assistant to let go of the arm and your done! It may take longer but a well balanced set of accurate blocks+springs can cut out the 10 minute tunin probs! then fine tune away again!
PacificaJonny is offline
post #9 of 10 (permalink) Old 12-25-2005, 04:53 AM
Also check that the retainerbar(the bar behind the nut where the strings go under) is not too high up. If so the strings are too far from the pads. If you lock the pads the strings go sharp...
Check it and screw it a little more down, until the strings stay virtually flat on the pads.
deloosem is offline
post #10 of 10 (permalink) Old 12-25-2005, 07:39 AM Thread Starter
thanks everyone, the strings are finally showing some stability.. lol, that's weird..haha but well, at least it wasnt so bad after applying those that u guys suggested! Happy Chirstmas and a New Year to all!
kelvin55 is offline
edge trem , locking trems , retaining bar
bolt-through locking nuts? whammybarofdeath All Other Guitars (including Prestige) 11 11-05-2009 12:53 AM
locking nuts coopertron Tech: Setup, Repairs and Mods 4 05-22-2009 11:17 AM
Locking Nuts seek_&_destroy Tech: Setup, Repairs and Mods 2 07-18-2008 02:19 AM
where to buy locking nuts? salami Tech: Setup, Repairs and Mods 6 02-17-2008 03:32 PM
Top mounting locking nuts? brothersnowgone Tech: Setup, Repairs and Mods 0 03-04-2006 12:25 AM
