Novice's new neck project question. - Jemsite
post #1 of 8 (permalink) Old 07-14-2011, 12:11 PM Thread Starter
I want to replace a Wizard II neck with a Super Wizard neck on a RG470. I imagine chances are slim it will just bolt on and work. Never replaced a neck before. This is not my main guitar so it's more like a Frankenstein project. Any tips or warnings would be appreciated. ^ ^
jer3d is offline
post #2 of 8 (permalink) Old 07-14-2011, 01:11 PM
Re: Novice's new neck project question.
If it has pre drilled holes they will probably line up okay, I've never had to redrill in the 3 times I've replaced Ibby necks.
GUITARMAGEDDON is offline
post #3 of 8 (permalink) Old 07-14-2011, 07:17 PM
Reviews: 120
Dont take it for granted that it will line up. You may well need to plug the holes with dowel and redrill them to match the body.
LonePhantom is offline
post #4 of 8 (permalink) Old 07-14-2011, 07:27 PM
in general and as noob - how "compatible" are wizard/prestige necks, assuming they are same scale and 24 frets? holes aside - could i switch the necks of my rg350, rg2550 and jem 77vbk around without any other issues? (i dont think i want the 350 neck on the jem, but i would be happy to know if i could :-) )
decypher is offline
post #5 of 8 (permalink) Old 07-14-2011, 07:58 PM
Reviews: 98
As long as the heel is the same width as the pocket--you'll be fine.
AlaskaBat is offline
post #6 of 8 (permalink) Old 07-14-2011, 09:00 PM
thanks!
decypher is offline
post #7 of 8 (permalink) Old 07-14-2011, 09:09 PM
RGTFanatic's Avatar
Yup.....All square heel RG neck are interchangeable with each other and the same goes for AANJ. you just have to watch out for 2005 and later aanj necks because they are 2mm wider at the heel (58mm as opposed to the 56mm heels of the 87-04's)
RGTFanatic is offline
post #8 of 8 (permalink) Old 07-15-2011, 01:17 AM
Reviews: 34
I've swapped loads of necks, including pgm rg and left handed onto right handed body.
As you say; as long as the scale length, no of frets and heel width are the same the worst you will have to do is plug and redrill holes.
nickcoumbe is offline
rg470 super wizard neck
Strat project question Canadian Mark All Other Guitars (including Prestige) 13 09-16-2008 09:48 PM
IBANEZ RG520QS Refinishing project question bdk All Other Guitars (including Prestige) 1 03-20-2008 01:17 AM
7-String project question.. ibanezrocker61 All Other Guitars (including Prestige) 6 03-13-2008 07:56 AM
Jem Custom Project Neck Question screamndemon69 Ibanez JEM, UV, JS & Other Signature Models 0 02-19-2007 09:03 AM
question from the project guitar site phil0333 Tech: Setup, Repairs and Mods 1 03-15-2005 09:12 PM
