Nut Height - Jemsite
post #1 of 27 (permalink) Old 12-28-2012, 07:13 PM Thread Starter
Unhappy Nut Height
So I have one last thing for setup on my guitar, I need to know the correct nut height. I know that Rich's site says .7mm too high but I don't fully understand what he means, I just need to know what the height of the nut should be. If I need to know what the clearance over the next fret is please tell me. I just don't understand what any of this means. What I do know is that the nut should be as low as possible without causing string buzzing, that's about it. If it helps I know for sure that the neck relief and action are fine, I have that setup correctly.
Ericson is offline
post #2 of 27 (permalink) Old 12-28-2012, 07:26 PM
Reviews: 98
Re: Nut Height
Follow Rich's advice.
If it's too high--remove shim.....if present.
AlaskaBat is offline
post #3 of 27 (permalink) Old 12-28-2012, 07:51 PM Thread Starter
Re: Nut Height
That's the thing.... I don't know when it gets too low or too high
Ericson is offline
post #4 of 27 (permalink) Old 12-28-2012, 08:17 PM
Reviews: 98
Re: Nut Height
By the action.
What's comfortable to you?
People have different tastes. Some like high action--most like low.
post #5 of 27 (permalink) Old 12-28-2012, 08:32 PM Thread Starter
Re: Nut Height
.......I'm not talking about the action here I'm talking about the nut height, I don't know what it's supposed to be set at
Ericson is offline
post #6 of 27 (permalink) Old 12-28-2012, 08:35 PM
Reviews: 98
Re: Nut Height
Nut height plays into the action. Action is the height of the strings off the fretboard--the nut plays a critical part in this. Nut too high= action too high. The bridge also is a part of this equation, but in your case--you think the nut is too high.
Are there any shims under the nut?
Rich went to great lengths to provide accurate info:
http://www.ibanezrules.com/tech/setup/nut.htm
A guide right here on Jemsite:
http://www.jemsite.com/articles-menu...-4-nut-height/
post #7 of 27 (permalink) Old 12-28-2012, 08:55 PM Thread Starter
Re: Nut Height
Well I think you finally gave me the answer, no the action is not part of the problem (like I said earlier....), no the bridge has nothing to do with this right now... but thank you
Ericson is offline
post #8 of 27 (permalink) Old 12-28-2012, 09:16 PM Thread Starter
Re: Nut Height
ROFL IM A DUMB ASS, it turns out all this time I've needed a ****ing neck shim LOLOL
Ericson is offline
post #9 of 27 (permalink) Old 12-28-2012, 09:32 PM
Reviews: 98
Re: Nut Height
Lol--that's always the easiest to check.
Glad you found the issue!
post #10 of 27 (permalink) Old 12-28-2012, 09:57 PM Thread Starter
Re: Nut Height
Wait.... I think I'm close to the answer... not sure... so I have one other question, is the distance between the first fret and the bottom of the string (being open), supposed to be the same as the distance between the next fret (holding the string down on the previous fret) to the bottom of the string as well?
Ericson is offline
post #11 of 27 (permalink) Old 12-29-2012, 01:14 AM
Re: Nut Height
Actually; it's to taste how high the nut should be. As high as you like without causing intonation problems, or as low as you like without open string buzz, or any height in between.
When I set up a guitar I usually set the nut up so that when I press the string IN FRONT of the second fret, I have a very small (.2mm or so) gap between the string and the first fret.
I find this is low enough for my comfort when chording in the lower positions but not so low I get any buzzing when playing open.
MicJustMic is offline
post #12 of 27 (permalink) Old 12-29-2012, 01:56 AM
RGTFanatic's Avatar
Re: Nut Height
Originally Posted by AlaskaBat View Post
By the action.
Both of these posts are telling you the secret to nut height adjustment. There is no "correct" height. It's entirely based on an individuals preferences for feel and action. When your guitar feels right while chording, the strings aren't buzzing too much, and your intonation is on the mark......... you found your perfect nut height.
RGTFanatic is offline
post #13 of 27 (permalink) Old 12-29-2012, 02:18 AM Thread Starter
Angry Re: Nut Height
Alright I think I finally understand the correct height, thank you everyone. But now there's another problem (****KKKK) so far my action is fine set at factory standards - 2mm bass, 1.5mm - trebble, neck relief is perfect at .4mm, bridge is completely level, and the nut height is low enough that it doesn't cause string buzzing when playing open notes. W00T ALMOST DONE... or so I think. The problem is the first fret of the low e string, I will play the first fret and I will get some string buzzing so now I am completely mind raped. To be honest if there's anyone out there that can just take my guitar in and find out what ever is wrong with the setup, the nut shims, or the neck shims I will pay you to do so I've spent about 2 - 3 years of my life with this and I'm pretty much just about done with all of it.
Ericson is offline
post #14 of 27 (permalink) Old 12-29-2012, 02:40 AM
RGTFanatic's Avatar
Re: Nut Height
DUDE, your working WAYY to hard on this. Is the buzz killing the note, or just annoying? With low action SOME buzzing should be expected. I'm sure you've posted it before, but what string gauges are you using? When you say the bridge is level; which part of the bridge is level to what? Factory specs don't mean squat. They're only a basic starting point. The same settings don't function on all guitars.
post #15 of 27 (permalink) Old 12-29-2012, 02:22 PM Thread Starter
Re: Nut Height
The buzz is annoying, standard .009 guages, the bridge is level to the body - it's not that hard to see if it's level or not.
Ericson is offline
setup
Nut Height? Stormcrow Tech: Setup, Repairs and Mods 5 09-28-2005 05:28 AM
EMG Height question Jslegacy Pickups & wiring 4 05-19-2003 11:32 PM
Height on EMG's? big h Pickups & wiring 1 04-23-2003 03:22 PM
String height on my UV Wadstein Tech: Setup, Repairs and Mods 3 01-15-2003 11:03 AM
PU height on EVO and FLO pri0531 Ibanez JEM, UV, JS & Other Signature Models 4 02-06-2002 10:28 AM
