Nut Height - Ibanez Rules article; still an issue ? - Page 2 - Jemsite
 5Likes
post #16 of 18 (permalink) Old 03-28-2018, 08:40 PM
Re: Nut Height - Ibanez Rules article; still an issue ?
Originally Posted by Rich View Post
You've probably adjusted everything else to your liking and if you added any relief it would increase first fret action.
I'm definitely setting this after I set the relief. It's been a little while I guess I can't remember what I was thinking? Sucks getting old!
Takin' a Ride is offline
post #17 of 18 (permalink) Old 03-30-2018, 07:44 PM
I was wondering why some models had a nut shim and why some didn't as my older cheaper '03 RG 320FM has a shim under the nut and i was wondering why. Good information.
CyberDreams is offline
post #18 of 18 (permalink) Old 03-31-2018, 07:27 AM Thread Starter
Bit of a datapoint.
I've got 3 RG Prestiges: A ~2008, knocked about, RG1570 - fairly cheap from a dealer; a ~2011 less cheap, ebay, used but tidy RG3250MZ; a new RG652KFX-KB.
On both the 3250 & 652, I would say the nut is way too high. In both cases, a tuner on the 1-5 frets says the intonation is all over the place [I've tried various intonation set-up schemes]. Tuning, esp on E6, needs to be something of a compromise.
[On the RG3250MZ, whoever had adjusted the bridge height, seemed to not understand the lock screws - which suggests a lack of clue.]
By contrast, the 1570 [which seems to have had a fairly hard, gigged life], has the nut height set in line with the article; and good intonation along the neck. I suspect it's been set up by someone that knows their stuff.
So, as you'd expect, this supports the view that an overly high, nut messes up tuning/intonation.
I reckon I'll shortly be looking at shimming the RG3250MZ nut; and probably have the local set-up guru look at the RG652 nut. [I don't mind gently twiddling things, but taking files to a new guitar is outside my comfort zone...] Though I might just take the RG3250MZ to the guru. He's friendly, and it's an interesting guitar.
scallybert is offline
ibanez rg nut
UV777BK pickup height issue Leviathus Ibanez JEM, UV, JS & Other Signature Models 13 04-06-2016 03:16 PM
UV70p Edge-Zero II-7 bridge saddle height issue panix Tech: Setup, Repairs and Mods 4 10-16-2014 09:35 AM
Ibanez S5EX1 Locking Nut Issue stevem48048 Tech: Setup, Repairs and Mods 5 09-02-2014 09:36 PM
Nut Height Ericson Tech: Setup, Repairs and Mods 26 01-01-2013 07:31 AM
Nut Height. Too high? Rich, do I have to file the nut base? MetalZone Tech: Setup, Repairs and Mods 7 08-21-2006 02:40 PM
