Nut issues - Jemsite
post #1 of 6 (permalink) Old 03-11-2004, 07:40 AM Thread Starter
Nut issues
ive bought a nut from allparts to replace my locking nut, however, it doesnt line up exactly right, it overlaps slightly on the bass side, so that the top e string will sit quite a way into the board, is there any solution to this, my dad has suggested making the holes in the neck larger so that the nuts have a small amount of play, enough to locate them properly in the new nut, any advice would be welcomed thanx.
woodros is offline
post #2 of 6 (permalink) Old 03-11-2004, 07:52 AM
ok dude, A few questions, What guitar is it for, And what is allparts return policy?
I would'nt recommend making the holes bigger, Not when for a few quid you can get the right nut.
If it's Ibanez, Goto Machinehead.co.uk or headstock distrubution (Ibanez distributor)
They will be able to solve the problemo
Rob
Jem7RB MK is offline
post #3 of 6 (permalink) Old 03-11-2004, 08:40 AM Thread Starter
thanx very much rob, its for an rg550, i asked rich before he said it was the closest nut i could get in terms of width, but i see your point, should've asked machinehead, seen as though they are ibanez people, we're not doing the nut today thank god, just the routing for the fil to put my new bridge on.
i got the nut from the pincotts supplier (uk) so ill have a look , it cost over 20 quid so i dont want to lose that.
just emailed pincotts im asking them how i can return the nut so fingers crossed
woodros is offline
post #4 of 6 (permalink) Old 03-12-2004, 12:54 PM
I wish Frank had OK'd the nut as he's alot more familiar with these aftermarket nuts. Anyway, sometimes even a factory nut will sit off to one side a hair where the old nut was centered perfect.
Rich is offline
post #5 of 6 (permalink) Old 03-12-2004, 01:19 PM
You just wish I had OK'd it so I could take the blame!
No, but seriously all you can do is match the radius and the width. There's no way to account for these stupid things. I have noticed that on narrower nuts it seems not to occur, but on the wider nuts it where it happens. It's like some people centered the holes across the nut width, while others kept the same dimension from one of the two sides, treble or bass. I have a Heartfield Talon I did with chrome hardware, and another custom neck with black hardware. The lock nut colors are opposite because when I tried the switch it was insane how much to the side they were. It was like they each favored the opposite side so when I tried switching them it was obsurd.
I wouldn't re-drill unless you had to. If you did I'd fill the old holes with real tight dowels first. Bear in mind you'll also have to widen the recess in the back to accept the bolt head. That part could be widened without filling it.
frankfalbo is offline
post #6 of 6 (permalink) Old 03-12-2004, 01:29 PM
Feiton recomends just grinding the edges of the bolt instead of widenning the seat hole, not like there's not plenty of meat there
Rich is offline
chrome hardware , lock nut , locking nut
HSH issues - SOS! Voice Of Reason All Other Guitars (including Prestige) 5 11-19-2010 01:39 PM
Issues with my RG so far... jm1681 Tech: Setup, Repairs and Mods 13 01-20-2007 02:35 PM
amp issues. littlewing777 Tech: Setup, Repairs and Mods 4 12-28-2006 02:24 AM
Jem YM-50 Issues... keithmoore Tech: Setup, Repairs and Mods 1 10-24-2006 02:31 PM
PM issues littlegreenman Off-topic / Miscellaneous 5 08-27-2005 02:04 PM
