Nut Shim - Jemsite
post #1 of 15 (permalink) Old 07-08-2011, 05:02 PM Thread Starter
Nut Shim
Anyone have any recommendations on what to use for a nut shim on an Ibby equipped with a LoPro when you don't have any of the standard shims? Thanks.
jemboyee is offline
post #2 of 15 (permalink) Old 07-08-2011, 05:20 PM
Reviews: 98
Re: Nut Shim
Cut up some business cards or other cardstock, Stack them if needed--works like a charm!
AlaskaBat is offline
post #3 of 15 (permalink) Old 07-08-2011, 05:26 PM
Re: Nut Shim
I like using metal. Aluminum can is about .1mm, just cut a can up.
Rich is offline
post #4 of 15 (permalink) Old 07-08-2011, 05:28 PM Thread Starter
Re: Nut Shim
Thanks. Would the business card trick work here as well, or is thin metal (coke can) the best option?
jemboyee is offline
post #5 of 15 (permalink) Old 07-08-2011, 05:30 PM Thread Starter
Re: Nut Shim
Whoops, didn't see AlaskaBat's post. I guess I'll give the business card option a go first. Don't have any aluminum cans. Thanks to the both of you.
jemboyee is offline
post #6 of 15 (permalink) Old 07-08-2011, 05:30 PM
Re: Nut Shim
Business card is about .3mm and alot thicker than you think. If you need that much the guitar was never playable.
Rich is offline
post #7 of 15 (permalink) Old 07-08-2011, 05:37 PM Thread Starter
Re: Nut Shim
Ok, putting the brakes on that idea. Perhaps I should describe the problem first. The action is a bit on the low side towards the nut end of the neck for the height it is at the heel end. Am I heading in the wrong direction thinking a nut shim is necessary?
jemboyee is offline
post #8 of 15 (permalink) Old 07-08-2011, 05:39 PM
Re: Nut Shim
it should be lower. If you want more add some relief.
Rich is offline
post #9 of 15 (permalink) Old 07-08-2011, 05:50 PM Thread Starter
Re: Nut Shim
Thanks. I'm aware that it should be lower, but it's lower than what I've normally experienced. I already gave about 1/4 turn earlier, so I'll give her another turn....
jemboyee is offline
post #10 of 15 (permalink) Old 07-08-2011, 07:58 PM
Re: Nut Shim
Shims and nut height in general have little to do with the overall action of the guitar. You can feel the change in the first position though.
Check for nut height: Tune guitar up, fret the string between the 3rd and 4th fret, and measure the gap between the bottom of the string and the top of the fret. You should have between .010" and .004 clearance. If the string rests on top of the fret, you need a shim.
musikron is offline
post #11 of 15 (permalink) Old 07-08-2011, 08:09 PM
Re: Nut Shim
+.2mm in nut height is + .2mm in action through at least the 5th fret, and it can definitely be felt.
I should have stated earlier, you can use relief to add clearance at the first, and action up till mid scale +, but not at the sacrifice of getting too high an action at the middle of the relief. You want the relief to be stable at your desired setting. Adjust the nut height if you want more string feel in the lower frets, or if it's creating too much buzz.
Rich is offline
post #12 of 15 (permalink) Old 07-09-2011, 09:49 AM
Re: Nut Shim
Stew Mac sells split shims for a really good price:
http://www.stewmac.com/shop/Nuts,_sa...Nut_Shims.html
I tend to prefer the split shims because I seem to never find a guitar with the same string clearance on both sides of the nut.
Takin' a Ride is offline
post #13 of 15 (permalink) Old 07-09-2011, 11:37 AM
Re: Nut Shim
Thats because most of us don't want the clearance even. Most players prefer more clearance on the bass side than the treble.
musikron is offline
post #14 of 15 (permalink) Old 07-09-2011, 03:08 PM
Reviews: 11
Re: Nut Shim
Aluminum Can. 65 cents.... O.o lol You have business cards, but not cans? lol
linuxpenguin is offline
post #15 of 15 (permalink) Old 07-09-2011, 04:13 PM
Re: Nut Shim
yep cans work great . i have also cut up larger picks to make shims out of . the triangle bass picks work great .
j.arledge is offline
Neck Shim warmachine67 Tech: Setup, Repairs and Mods 7 06-05-2011 02:54 PM
Neck shim+nut shim=better tone? bringer of torture Tech: Setup, Repairs and Mods 4 04-20-2008 04:09 PM
Need shim help! BobS Tech: Setup, Repairs and Mods 6 05-27-2005 08:07 PM
what i found under my nut shim Jagermeistro Ibanez JEM, UV, JS & Other Signature Models 12 02-11-2005 04:16 PM
Does this mean my nut needs a shim? Kremlin Tech: Setup, Repairs and Mods 10 04-08-2003 11:30 AM
