ongoing neck problem (S470DX) - Jemsite
post #1 of 2 (permalink) Old 01-07-2006, 02:24 AM Thread Starter
hi guys. ive had a problem for a while now, it first started when i had the arm holder on the ZR tightened to stop the wobble, that worked but gave me a horrible side effect, a dead-ish spot from around the fifth fret to the seventh on the g string the notes (Particularly the seventh fret) played, but did not sustain as long and had a choked/muffled sound. i suppose the neck warped or moved while the tention of the strings was relaxed. i got used to it.
Just resently i had a dimarzio X2N installed (sounds great) and of course all of the strings had to be taken off during the process. after it was put in i went home and changed the strings, same gauge, same brand (D'addario 9-46) after i tuned up and stretched the strings i noticed a dead note, its the 14th fret on the g string. it plays and makes a horible choking sounds and rings for only around a second or two. I am quite certain that it is the frets rattling. But my question is why is it warping each time i release some tention? is there something i could do with the truss rod to stop these unwanted shifts?
I suppose ill be getting a fret dress some time later but i need to know this isnt going to happen again and strip me of $90 they carge for a fret dress.
thanks, Jarrad
superhairycamel is offline
post #2 of 2 (permalink) Old 01-07-2006, 08:17 AM
Re: ongoing neck problem (S470DX)
try highering your action and see if the problem persists, if not, i think itll just be a fret dress needed. I'm not too bright in this area though but don't ask the salesman he'll just persuade you to have it done so he can get your $$$!
PacificaJonny is offline
arm holder , truss rod
the ongoing pickup discussion continues.. _LeviathaN_ Pickups & wiring 8 08-15-2008 07:29 AM
Photograph weekly (or so) & ongoing assignmentts wilch Off-topic / Miscellaneous 160 05-16-2008 08:02 PM
F/T Ibanez S470dx jjegg Classified Ads: Guitars and Gear 0 04-01-2007 06:40 PM
s470 or s470dx zulumika All Other Guitars (including Prestige) 4 10-11-2004 05:50 PM
