Original Edge Trem - Replace the block? - Jemsite
post #1 of 5 (permalink) Old 08-18-2009, 08:18 PM Thread Starter
Reviews: 3
Wink Original Edge Trem - Replace the block?
Hi guys,
I have a couple of Edge trems spared up for upcoming projects and I am thinking about upgrading to a bigger block.
The trems seems pretty solid themselves so I'm not 100% as to whether or not this would be time well spent.
The main consideration is that they are obviously the size that they are to maximise trem movement and any thing more could have quite negative implications with regards to movement. Also, I cant see it being worthwhile routing the body to accomodate the larger block if the benefits are only going to be minor.
The only reason I am thinking of this is because I have had good results when standard strat trem blocks but as I said, the base of the edge is already quite solid and robust by comparison... so ... a few opinions here would be a great help.
Many thanks
kigorri is offline
post #2 of 5 (permalink) Old 08-18-2009, 08:44 PM
Re: Original Edge Trem - Replace the block?
Hi
I have been wondering the same thing and a couple of your questions are answered in this thread.
http://www.jemsite.com/forums/f21/te...red-93200.html
“buddroyce” is the guy on Jemsite to talk to if you want to buy one.
VBK-Shredder is offline
post #3 of 5 (permalink) Old 08-18-2009, 09:20 PM Thread Starter
Reviews: 3
Originally Posted by VBK-Shredder View Post
Hi
WOW lol
Thanks for that, my 'seach fu'was a little weak and I didn't read you thread seeing as I don't fancy myself as a technical genius haha.
Hmm... so... bell brass... I thought solid steel was better as brass tends to absorb more of the higher end freq's, I guess this is where the 'darker' sound comes from.
Arming adjuster, sounds interesting... I'll need to search one of these.
kigorri is offline
post #4 of 5 (permalink) Old 08-18-2009, 09:48 PM
Originally Posted by kigorri View Post
WOW lol
That’s what’s different about Bell Brass you (should) retain those frequencies.
post #5 of 5 (permalink) Old 08-19-2009, 01:50 AM Thread Starter
Reviews: 3
Sweet as. Here's me thinking that Brass is Brass
kigorri is offline
block , edge , original edge , upgrade block
Replace Edge-ZERO with Original-EDGE? SilverEra Tech: Setup, Repairs and Mods 7 06-25-2009 04:36 AM
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 01:22 AM
FT: Floyd Rose Brass Trem Block for Ibanez Edge Block t1r12003 Classified Ads: Guitars and Gear 0 02-27-2009 09:19 PM
Need to replace original Edge trem posts ... many questions. JohnnyRasgueado Tech: Setup, Repairs and Mods 19 04-15-2004 12:34 PM
Want to replace my old Low-Pro Edge trem karibou Ibanez JEM, UV, JS & Other Signature Models 8 07-17-2003 11:38 AM
