Original Floyd Rose Pro and Ibanez Trems - Jemsite
post #1 of 5 (permalink) Old 07-07-2002, 11:23 PM Thread Starter
Hi,
Will Ibanez replacement parts work on my Floyd Rose Pro. I have an old Kramer Proaxe which has the original Floyd Rose Pro tremolo. I beleive the Lo Pro Edge is based on this trem.
The tremolo arm socket (the receptical that the trem arm goes into) needs to be replaced. Can I use the Lo Pro Edge replacements parts?
Thanks for any info.
KingsXFan is offline
post #2 of 5 (permalink) Old 07-07-2002, 11:43 PM
I believe that if you remove the bar holder, you can easily replace it with an Ibanez push-in type bar. Seems like I've heard of guy's doing the swap the other way (Floyd holder into LoPro) so it should work the way you're thinking. However, try at your own risk.
dcord is offline
post #3 of 5 (permalink) Old 07-08-2002, 02:48 AM
I don't think it would fit. I had to do the reverse - Schaller Floyd arm holder into a busted Edge (didn't like it but I couldn't get an Ibanez arm holder at the time) - and the tech who did it had to drill the hole out to make it wider. So I'd guess that an Ibanez arm holder would be too narrow to fit an OFR socket.
It's a shame, because if you could drop the push-in arm holder into any FR-licensed trem, I'd never have a problem buying any non-Ibanez locking-trem guitar again...
mecca777 is offline
post #4 of 5 (permalink) Old 07-08-2002, 02:58 AM
He drilled the hole out? He could've just filed down the threads inside the base-plate hole a little and would've slid right in, worked that way for me on three trems(2 Edge, 1 LoPro7).. Either way, the hole in your Floyd Pro is probably going to be too big for an Edge/LoPro arm.. Never tried it, so I can't be sure, and I sold my Floyd Pro 6 months ago, so I can't check..
You should be able to get a regular Floyd bar assembly easy, F*nder sells them in a blister pack for like $12, I think..
toshiro is offline
post #5 of 5 (permalink) Old 07-08-2002, 04:16 AM
i dont know if it'll fit on a OFR, but i think it wont work properly.
the thing is that the OFR arm-socket works by tighten it to the baseplate, and the Edge/Lo-Pro works also because of the thickness of its baseplate.
the baseplate thickness is the matter that does the difference on the Edge/Lo-Pro.
nuno is offline
arm holder , floyd rose , floyd rose pro , pro arm , pro edge , pro tremolo , trem arm , trem guitar , tremolo arm
Fit original Floyd Rose in Ibanez RG2550E Alfi27 All Other Guitars (including Prestige) 4 04-09-2013 11:33 PM
Ibanez RG470 Resurrection - Lo-TRS to Floyd Rose Original Retrofit hammer All Other Guitars (including Prestige) 6 03-24-2013 05:50 AM
Floyd Rose Licensed trems at Guitarpartsdepot StevenMikel Tech: Setup, Repairs and Mods 28 06-25-2009 06:36 PM
Original Floyd Rose or Ibanez Edge? Dee Polls 26 07-14-2006 11:11 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 01:06 AM
