Original Floyd Rose Replacement query - Jemsite
post #1 of 9 (permalink) Old 03-06-2018, 12:16 PM Thread Starter
Hi all,
I am thinking of replacing the Original Floyd Rose on my guitar to make it feel closer to my other guitar which is equipped with an Edge Zero when palm muting as the saddle edge feels sharp on the OFR.
Right now I'm choosing between a Gotoh GE1996T and a Floyd Rose Pro
Would like to hear your opinions
V-Trigger is offline
post #2 of 9 (permalink) Old 03-06-2018, 05:38 PM
Re: Original Floyd Rose Replacement query
The Gotoh bridge is the same as the Original Floyd Rose, the Floyd Rose Pro is probably closer to what you're looking for in terms of palm feel, but it all depends on your fingerboard radius. The Floyd radius is 12" and the Pro is 16", it needs to match your existing radius, or be close enough that it doesn't bother you.
Keefermadness is offline
post #3 of 9 (permalink) Old 03-06-2018, 10:08 PM
Reviews: 120
The Gotoh bridge is lower profile than OFR, while still retaining the general style. The saddles are more rounded off, like the original Edge, etc, so it's going to feel smoother under the hand than the Floyd Rose options.
LonePhantom is offline
post #4 of 9 (permalink) Old 03-07-2018, 04:30 PM
You are correct sir, they are indeed slightly lower and rounded, much more so that the Floyd. If this bridge suits your requirements I highly recommend it, even over the Original Floyd Rose, but don't tell Floyd I said that.
post #5 of 9 (permalink) Old 03-08-2018, 10:57 AM Thread Starter
double post
post #6 of 9 (permalink) Old 03-08-2018, 10:58 AM Thread Starter
Seems like the Gotoh Floyd Rose is what I'm looking for with your guys description of the rounded saddles on it.
Another question, Would the difference in radius between the Gotoh FR and OFR be prominent enough to be felt when playing or is it negligible?
It would be better If I could try a guitar equipped with it beforehand but I think only Suhrs and EBMMs have the Gotoh Bridges stock on their FR equipped guitars. Any more readily available guitars equipped with the Gotoh FR Bridge?
Many Thanks!
post #7 of 9 (permalink) Old 03-08-2018, 05:03 PM
The radius on the Gotoh and Floyd are the same, 12", it should suit you purposes nicely.
I've only ever seen the Gotoh mounted on Ernie Ball Music Man guitars. If you like the Floyd tremolo you will like the Gotoh better, they're very similar in feel and performance but the build quality and finish are better on the Gotoh.
post #8 of 9 (permalink) Old 04-02-2018, 03:34 PM Thread Starter
Got the Gotoh Floyd and installed it in my guitar, it now has that feel that I was looking for. No more annoying sharpness for when my right hand is resting on the bridge.
My guitar's sound changed and became slightly warmer though even with the new strings.
Overall, a worthwhile change I think, would recommend it over the OFR.
post #9 of 9 (permalink) Old 05-05-2018, 10:21 PM
You can change the radius of the bridge to suit with under saddle shims, keep your original nut on the guitar as it will already match your fretboard radius
ChAoZ is offline
floyd rose
Floyd Rose Original or Floyd Rose Pro enb141 Tech: Setup, Repairs and Mods 8 09-09-2011 04:51 PM
WTB Original Floyd Rose or GOTOH floyd rose callen3615 Classified Ads: Guitars and Gear 3 01-22-2011 03:12 PM
FS: Original Floyd Rose & Floyd Rose 2 -zct- Classified Ads: Guitars and Gear 6 09-02-2005 04:07 PM
Original Floyd Rose or Floyd Rose Pro? Fatal-Tragedy Tech: Setup, Repairs and Mods 3 08-03-2004 10:56 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 01:06 AM
