Original floyd Rose tuning stability help - Jemsite
post #1 of 9 (permalink) Old 07-07-2011, 02:49 AM Thread Starter
Post Original floyd Rose tuning stability help
whenever I pull up on the floyd rose or raise the pitch of the note it keeps going flat!
so to remedy this I always have to dive down what should I do so I don't have to dive down to keep it in tune?
and another question when tuning and setting up the OFR
while adjusting the springs and tuning so the bridge is parallel to the body should the guitar be flat on a surface or in playing position?
IbanezRgEX is offline
post #2 of 9 (permalink) Old 07-07-2011, 02:55 AM
Re: Original floyd Rose tuning stability help
Typical symptoms of a loose locking nut.
Every adjustment should be made in playing position.
Rich is offline
post #3 of 9 (permalink) Old 07-07-2011, 11:28 AM Thread Starter
now that you mention it whenever I lock the nuts the whole locking nut set moves ,but the thing is it's as tight as it can get and it still moves
post #4 of 9 (permalink) Old 07-07-2011, 11:28 AM Thread Starter
I mean the screw that screws in to the guitar that holds it in place
post #5 of 9 (permalink) Old 07-07-2011, 01:19 PM
screwed from the back, or woodscrews from the top down? If it's screwed from the back, they could be too long, and you are screwing the retaining screws against the locking pads. Get shorter screws, or try to shim the nut up with some sanding screen or sandpaper, or paper to see if that gets it locked into place better. If the locking nut moves, it won't stay in tune for sure!
andrewgosline is offline
post #6 of 9 (permalink) Old 07-07-2011, 11:22 PM
Reviews: 3
If that's not the problem, put chapstik on the posts and knife edges
IBZshredder is offline
post #7 of 9 (permalink) Old 07-09-2011, 09:23 PM Thread Starter
Post Re: Original floyd Rose tuning stability help
I've now tightened the screws that goes to the neck of the guitar for the locking nuts (it was a bit loose)
now how would you check if the bridge is parallel to the guitar rather than eyeballing it?
post #8 of 9 (permalink) Old 07-09-2011, 09:30 PM Thread Starter
it's a pain to see if it's parallel or not and after when I think it's parallel ,I finally tune it - lock it - fine tune it then finally divebomb down (stays in tune) divebomb up (it goes flat or sharp)
the locking nut fix did seem to help though..
post #9 of 9 (permalink) Old 07-09-2011, 09:32 PM Thread Starter
I am looking if it's parallel or not from playing position view ,not on a flat surface as Rich suggested
floyd rose tuning
WTB Original Floyd Rose or GOTOH floyd rose callen3615 Classified Ads: Guitars and Gear 3 01-22-2011 02:12 PM
Original Edge tuning stability problem Winter Tech: Setup, Repairs and Mods 8 06-08-2010 03:47 PM
Low tuning and floyd rose straymond Tech: Setup, Repairs and Mods 4 12-03-2009 06:06 PM
Tuning Problems&OFR(Original Floyd Rose)Question Important! Ibanez/OFR Compatibility atcgtr Tech: Setup, Repairs and Mods 13 12-21-2008 03:18 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 12:06 AM
