PGM wiring question - Please help, pretty please!! - Jemsite
post #1 of 17 (permalink) Old 07-28-2011, 11:12 AM Thread Starter
Greetings!
I picked up a Lollar single coil to put in the neck of my PGM 301 and it sounds really thin and I was wondering if I did this correctly?
PAF PRO = 4 conducto
Lollar = 2 conductor
I simply ran the hot lead from the lollar to the pin where the RED wire from the PAF PRO was attached to the 5 way. It switches fine but just sounds very thin and shrill. Do I need to jump some leads on the 5 way to compensate for it being only 2 conductor?
Any input is greatly GREATLY appreciated!
Many thanks,
~J
Josh_P is offline
post #2 of 17 (permalink) Old 07-28-2011, 11:18 AM
Re: PGM wiring question - Please help, pretty please!!
well, it's much less powerful than bridge pickup, so you may be hearing a huge drop in volume when switching to neck. Maybe that's the problem
bancika is offline
post #3 of 17 (permalink) Old 07-28-2011, 12:23 PM Thread Starter
The volume is right on / equal to my bucker but it just has really shrill highs and no bass like you would expect with a SC in the neck.
many thanks for the reply!
Josh_P is offline
post #4 of 17 (permalink) Old 07-28-2011, 01:02 PM Thread Starter
guess it would be easier to simply ask
How do I wire a 2 conductor single coil in neck position to a VLx91 switch?
Josh_P is offline
post #5 of 17 (permalink) Old 07-28-2011, 02:14 PM Thread Starter
I would also like to add that Iíve thoroughly searched the older posts for over 45 minutes and found nothing in regard to wiring a 2 conductor single coil in the neck : v (
Josh_P is offline
post #6 of 17 (permalink) Old 07-28-2011, 06:04 PM
Reviews: 120
Sounds to me like you've wired it correctly.
Issue is, was this pickup designed primarily to go in a Strat?
Strats have 250K pots, where as guitars primarily with humbuckers have 500K pots. The higher the resistance the pot, the brighter, and perhaps the more shrill a pickup will sound.
I have a feeling you are just hearing how that particular pickup will sound when its paired with a 500K pot.
I wonder (and I've only just thought of it, it very well may not work), if you put a 250K resistor inline with the pickup 'hot' wire and pickup selector, whether or not that will throw in the equivelant resistance you would have if you had just a 250K pot in the guitar?
Might be worth a try, and would only cost a few cents.
LonePhantom is offline
post #7 of 17 (permalink) Old 07-28-2011, 06:15 PM
Reviews: 120
Sorry I really didn't think hard enough about that idea, still waking up. It'll probably just halve the volume.
post #8 of 17 (permalink) Old 07-28-2011, 07:05 PM
it wouldn't be equivalent or even close. When volume is maxed you would dump 1/3 of the signal because you'd form a voltage divider with 250K inline and 500K to ground.
You could fake it with a 500K resistor between outer lugs of the pot and it would work as a 250K pot when maxed, but pot taper would be slightly altered.
bancika is offline
post #9 of 17 (permalink) Old 07-28-2011, 10:43 PM
Reviews: 120
Thats why I responded with my retraction of the idea after I wrote it. Didn't think it fully through.
post #10 of 17 (permalink) Old 07-29-2011, 08:07 AM Thread Starter
Thank you guys so much for solving the mystery! I'm running a Dimarzio mega drive in the bridge. You guys think the humbucker would sound like crap if I jumped the outer lugs making it a 250k?
Josh_P is offline
post #11 of 17 (permalink) Old 07-29-2011, 08:08 AM Thread Starter
I've also read that I can put a resistor in parrallel with the single coil however I can't wrap my mind on how to wire it.
Josh_P is offline
post #12 of 17 (permalink) Old 07-29-2011, 08:33 AM
Reviews: 120
I reckon if you try a 250K pot setup there is a chance your humbucker might get a bit muddy. The good news is you can solve that issue to some extent by putting a 0.047uf or lower (maybe 0.01uf, anything in-between) capacitor between the humbucker's hot wire and the switch. I have info on it in the DIY section of my blog if you want to try the cap. It's in an article called "Taming the Tone Zone". There's a few parts to it.
http://www.lonephantom.com
Hope that might help.
post #13 of 17 (permalink) Old 07-29-2011, 10:27 AM Thread Starter
Many thanks man! I really want to stick with the 500k pot and just modify the single coil circuit if at all possible. After all the discussion, what's your best advise for that?
1,000,000,000 thanks once again man.
Josh_P is offline
post #14 of 17 (permalink) Old 07-29-2011, 10:32 AM Thread Starter
OK, I think I got it!
Taken from here: http://www.thegearpage.net/board/arc.../t-822758.html
Will try adding a 500k resistor in parallel from the bridge pickup's hot lead to ground
Josh_P is offline
post #15 of 17 (permalink) Old 07-29-2011, 04:33 PM Thread Starter
wired up the 470k resistor from hot lead to ground and it fixed completely. Even volume, fat tone and the pot roll off wasn't affected at all. Loving this HSS config
Josh_P is offline
lollar , pgm , single coil
5-way wiring question for h-s-h gkelm Pickups & wiring 15 03-19-2010 10:50 AM
Question about wiring christiancoker1 All Other Guitars (including Prestige) 4 02-06-2010 07:08 PM
PUP Wiring Question aliqamar Pickups & wiring 50 05-29-2007 03:43 AM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 07:06 AM
Re-Wiring Question - Ha, semi-related to the "Wiring Questio Two hands31 Tech: Setup, Repairs and Mods 19 01-03-2002 06:26 PM
