Pickup Problem - Jemsite
post #1 of 2 (permalink) Old 01-22-2007, 03:14 AM Thread Starter
Unhappy Pickup Problem
Ahoy there!
I've been reading the forums for a while but this will be my first post, so here goes:
I have a stock '99 Jem7DBK, and recently the bridge pickup died out on me. The neck and single pickups are working fine, but when the pickup switch is in the bridge pickup position, there isn't any sound unless I crank my amp's volume to max, in which case then I hear a very faint sound.
When I have the switch on the bridge pickup and middle pickup in parallel, it sounds just as if the middle pickup is working alone.
I haven't taken a look at the electronics yet because I just put on a new pack of strings and don't want to waste them, but I'll open the puppy up before the next string change. I think I'm capable of handling any minor fixes but any inputs/ideas of what might be wrong would be greatly appreciated before I take a go at it.
Also, the pots have become rather scratchy, and I plan on replacing them in the near future. Not sure if the two problems are related, but had to point it out just in case.
Anyways, thanks in advance for any help
Cheers
kai715 is offline
post #2 of 2 (permalink) Old 01-22-2007, 03:54 AM
Re: Pickup Problem
Probably the hot connection from the bridge PUP came loose. All you need is to solder it back on if that is the case.
waylay00 is offline
bridge pickup , bridge pup , pickup switch
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 11:57 AM
Did I melt my pickup?!? giannifive Pickups & wiring 3 03-09-2005 01:10 AM
What is this pickup Heka Pickups & wiring 1 07-22-2003 02:11 AM
Pickup Problem Two hands31 Pickups & wiring 4 06-11-2002 08:03 AM
I'm new here, need pickup suggestions ! - I just bought a 77 rockfish Ibanez JEM, UV, JS & Other Signature Models 8 03-31-2002 04:30 AM
