Pickup Routing question. - Jemsite
post #1 of 4 (permalink) Old 09-30-2004, 11:33 PM Thread Starter
Hi, Im building a body for my rg570 neck, but i need the routing dimensions for 2 humbuckers,. does somenone knows that?
Thanks....!
JN777 is offline
post #2 of 4 (permalink) Old 10-01-2004, 01:55 PM Thread Starter
JN777 is offline
post #3 of 4 (permalink) Old 10-01-2004, 05:31 PM
You can take a regular humbucker mounting ring, trace around it at the location you want the pickup, and then draw in the "ears" large enough to accept whatever brand of pickup you're using but not so large they protrude from the mounting ring. If you're not using a mounting ring then you can do whatever you think looks best. There's no standard route. There are routes that will fit most or all pickups, but not a standard size route. If you're using Dimarzio's you might want the little triangle ears like some Ibanez guitars have. If you're using Duncans or Gibsons you might just want an oval, or even take a forstner bit and drill for the ears first, before routing the inner square. The "old standard" Ibanez route has one ear longer than the other to accomodate the old pickups that had 2 screws on one side and one screw on the other. If you're using that kind of pickup, or a Carvin with two screws on each side, you need a larger ear size.
frankfalbo is offline
post #4 of 4 (permalink) Old 10-01-2004, 11:27 PM Thread Starter
thanks for the info!
JN777 is offline
ibanez guitars
wiring routing question yamasaki760 Pickups & wiring 27 12-07-2012 05:56 PM
one more pickup question for RGA's... covered pickups fit the routing? JoshuaLogan All Other Guitars (including Prestige) 2 03-18-2007 12:57 PM
Pickup routing AND refinishing vendor? GreasyKid Tech: Setup, Repairs and Mods 0 09-02-2006 06:39 PM
JEM trem cavity routing question Major Tom Ibanez JEM, UV, JS & Other Signature Models 2 07-11-2006 11:34 PM
Best way to get a new pickup routing.... ProFragger Pickups & wiring 4 03-21-2005 01:30 AM
