Please help needed!! - Jemsite
post #1 of 15 (permalink) Old 09-20-2012, 03:28 PM Thread Starter
Hi there
Im having a very annoying problem with my 7V and desperately need advice. Ive recently taken my Jem to my local music shop (well trusted in my area) and it re-strung (strings all well stretched in) and a set up adjustment.
However,
When I depress the tremolo bar, the tone of the G B & E strings lowers a few semi tones
Likewise when I pull up the tremolo bar, this raises the overall tuning a few semitones higher
... This is really very annoying and I can't seem to resolve the issue, no matter how many times I re-tune and re-stretch the stings.
The guy in the shop says there is nothing wrong with my trem however there must be something I can do to stop this very annoying issue!!
Your help as always is greatly appreciated!!
Gemguy67 is offline
post #2 of 15 (permalink) Old 09-20-2012, 03:43 PM
Re: Please help needed!!
Maybe the nut is slipping back and forth,needs tightening.
moonlight is offline
post #3 of 15 (permalink) Old 09-20-2012, 05:10 PM Thread Starter
Sorry I'm not very clued up so you will have to bear with me
Are you referring to the locking nut? If so I've made sure this is tightened securely
Thanks for the reply
Gemguy67 is offline
post #4 of 15 (permalink) Old 09-20-2012, 05:49 PM
Reviews: 15
Not only the pads but the 2 screws that hold it to the neck too.
silverctr is offline
post #5 of 15 (permalink) Old 09-20-2012, 08:43 PM
Agreed this is fairly common but be careful not to over tighten those screws (the ones that go through the neck) - that is how people get cracks in their neck.
Another common issue, especially if it was just cleaned & set up, is lack of lubrication on the tremolo studs where the trem knive edges contact them. A little Chapstick works wonders here an is clean & cheap.
kfssdude is offline
post #6 of 15 (permalink) Old 09-21-2012, 01:09 PM Thread Starter
Gents thanks very much for this
I'll give it a go and re-post with the outcome
Gemguy67 is offline
post #7 of 15 (permalink) Old 09-23-2012, 03:35 PM
RGTFanatic's Avatar
Welcome to Jemsite, Gem!!!
I'll be the one to ask the obvious question:
Are the stud locks locked??
RGTFanatic is offline
post #8 of 15 (permalink) Old 10-03-2012, 01:51 PM Thread Starter
Yo
I've tried the above guys and it is still having the same issues, any further suggestions?
Haha sometimes the obvious is missed. But yea, they're all locked down buddy.
Gemguy67 is offline
post #9 of 15 (permalink) Old 10-03-2012, 02:06 PM
How old is the guitar? Maybe the knife edges in the trem are due to be replaced? On that note, which trem do you have?
Another possibility is the stud anchors have become loose in the body. This is common on older guitars or if you are a particularly vigorous trem user. This is a much more serious issue, but is fixable. Rich has put up a good outline of the fix procedure in the tech section of his site (Ibanez Rulez). Speaking of which, have you gone through that tech section yet? He offers good advice on troubleshooting this exact problem (along with many others). It really is a must-read.
kfssdude is offline
post #10 of 15 (permalink) Old 10-03-2012, 02:29 PM
Dive makes them flat, pull makes them sharp. Yep, sounds like anchors rocking back and forth. ^
axel_f is offline
post #11 of 15 (permalink) Old 10-14-2012, 12:00 PM Thread Starter
Guys thanks for this, Ill read have a play around re-post! Thanks again
Gemguy67 is offline
post #12 of 15 (permalink) Old 10-15-2012, 06:18 AM
Contributor
sebastian's Avatar
Did it do this before you took it to the tech?
sebastian is offline
post #13 of 15 (permalink) Old 10-15-2012, 02:47 PM Thread Starter
It did indeed bro... my day off is wednesday. So ill attempt to take it apart and maybe post pics if I have time.
Gemguy67 is offline
post #14 of 15 (permalink) Old 11-11-2012, 08:34 AM Thread Starter
Gents, the problem was the knfe edges. There was a bit of wear that needed to be filed down, that and a bit of lubrication and im all set and the problem appears to have been resolved! Thanks again for your help much appreciated
Gemguy67 is offline
post #15 of 15 (permalink) Old 11-11-2012, 11:12 PM
RGTFanatic's Avatar
Glad you got it figured out man!!!!!
Congrats!! enjoy that monster now!!!
repairs
tab needed Hartfolk Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 12-02-2006 11:05 PM
RGR 570 ? Help needed on a buy Silverburst All Other Guitars (including Prestige) 16 10-14-2006 02:44 AM
Help needed with an RG 340 PatrickSimsCustomShopUSA All Other Guitars (including Prestige) 8 08-03-2006 04:53 PM
RG 550 Needed, please! schecter_blue Classified Ads: Guitars and Gear 18 06-04-2005 02:24 PM
Help needed... Wis Redz of Silvanost Ibanez JEM, UV, JS & Other Signature Models 9 10-23-2004 02:11 PM
