Popping sound when using Edge 2 Trem. - Jemsite
post #1 of 3 (permalink) Old 12-11-2018, 09:45 AM Thread Starter
So yesterday I bought an Ibanez RG350ZB with the Edge 2 Tremolo, its a beast of a guitar and doesn't go out of tune.
But probably 10 mins ago I was using it after I turned off my amp and could hear cracking, then I saw this piece of plastic cracked, would it be plausible that this is the cause or is it another issue? and would I be able to replace it?
youtube vid of it making that sound.
File Type: jpg 48178026_2277948278906367_3901470647267622912_n.jpg (51.0 KB, 24 views)
bad21 is offline
post #2 of 3 (permalink) Old 12-11-2018, 10:00 AM
It's supposed to look like that, the split is there so you can remove the bush easily and replace it, if it weren't split you have to destroy it to remove it and you'd be unable to fit a new one. They wear out.
sepulchrave is offline
post #3 of 3 (permalink) Old 12-11-2018, 04:41 PM
Re: Popping sound when using Edge 2 Trem.
Could it just be the bar that is moving/rocking in the socket?
One downside to that bar design to me is that it one has just the one bushing (The Edge, Low Pro etc. all have two). I fixed my EZ II arm from doing this by wrapping electrical tape around the base before inserting the bar in the socket.
Mattww is offline
floating trem problem
Cracking and popping sound when recording Axe Fx with my SB Audigy2 Silverburst Gear, Equipment, Recording & Off Topic 5 05-16-2010 01:16 PM
Neck Popping when using Bar! sniperfrommars1 Tech: Setup, Repairs and Mods 11 07-28-2006 04:53 PM
Line 6 Flextone, popping sound. RSVampire Tech: Setup, Repairs and Mods 0 04-29-2004 12:30 AM
Neck making "popping" sound? leishan Tech: Setup, Repairs and Mods 4 01-20-2003 05:04 PM
popping sound from my amp? - please help me? jem7vwh Gear, Equipment, Recording & Off Topic 3 08-21-2001 11:27 PM
