possible to do a finish using paintbrush? - Jemsite
post #1 of 7 (permalink) Old 12-12-2005, 11:34 AM Thread Starter
possible? im thinking of using normal paintbrush and pain some some stuff over my guitar, and apply a few layrs of laquer is tat possible?
extigy is offline
post #2 of 7 (permalink) Old 12-12-2005, 01:58 PM
Re: possible to do a finish using paintbrush?
Yes it is possible. Though, it will be a little difficult to get a smooth flat finish (i.e. flat to feel, rather than "matte"). I guess what you plan to do is use the clear coat to act as your flattener.
Ibateur is offline
post #3 of 7 (permalink) Old 12-13-2005, 02:24 AM Thread Starter
im thinking of getting normal wall paint and paint over my guitar body. do paint stay on laquered surface? and after my painting, should i sand it to smooth it out? I will be drawing some stuff and will sanding it destroy the drawings? maybe i should try out, if not, i guess i juz apply more layer of laquer and sand and laquer it again? if i wan a non-glossy finish, i should juz apply laquer and sand it right? without buffing it?
extigy is offline
post #4 of 7 (permalink) Old 12-13-2005, 04:28 AM
I tried applying primer to a body with a brush. I found that no matter how good my brush was, the streaks appeared and were very difficult to sand away. I just ended up getting a spray can primer which worked.
I would suggest sanding the body before painting over it. It helps to prevent the paint from peeling off, especially if the guitar body has a nice shiny clearcoat on it. After a rough feel, lacquer should stick to it.
You can sand after painting, but that may indeed damage the drawing. If your drawing is flat, I would suggest directly clearcoating over that. If you want a matte (non-glossy) finish, you should get a matte clear coat can - cans!
Ibateur is offline
post #5 of 7 (permalink) Old 12-13-2005, 05:01 AM
if your guitar is already painted and clear coated...... you can hand paint some graphics on it... using createx paints......or something like parma faskolor acrylic paint will work.......that how a airbrusher would do graphics......but they use a combo of paintbrush and airbrush as far as i know anyways......then clear coat it......
and if you mess up.some rubbing alcohol should remove the paint you can google a search for airbrushing.....and will find some how to lessons..... normally lessons for cars or mototcycles but its the same princible
honky_tonk is offline
post #6 of 7 (permalink) Old 12-13-2005, 06:31 AM
Talking Re: possible to do a finish using paintbrush?
Bro paint's can react badly if you use the wrong type's of paint & trying to coat with diffrent paint's will result in a bad job! if you use a Auto paint then use the same paint in a clear coat, & the same goes for any type of paint you use, make sure it's all the same paint brand, goodluck with the project!
Cheers- Jake
jaken777 is offline
post #7 of 7 (permalink) Old 12-13-2005, 08:39 AM Thread Starter
hmm, use spray cans seem hard for me. I had tried spraying a pickguard before. the finish was a nightmare, uneven surface and bubbles around. Actually I am doing this one a spare body that had been around my storeroom for sometime. Its a agathis body super strat body. Im thinking of using those art painting paint? What did you call it? i barely remember the name, poster colour? or something near to that
extigy is offline
clear coat , guitar body , strat body , super strat
Want to take finish off RG Ke^in Tech: Setup, Repairs and Mods 47 07-15-2012 02:19 AM
would screwing holes in finish for pickguard crack or ruin the finish l0k1 Tech: Setup, Repairs and Mods 4 12-03-2009 12:48 AM
How to get this finish??? jlander Tech: Setup, Repairs and Mods 7 03-01-2006 09:58 PM
Can EKG do me a 7RB ? LGM RB finish ? Jem7RB MK Ibanez JEM, UV, JS & Other Signature Models 3 01-02-2004 08:05 PM
RG-2027X Finish vs. RG-2127X Finish pd0x All Other Guitars (including Prestige) 12 09-29-2002 10:11 PM
