Pot/switch swap? - Jemsite
post #1 of 6 (permalink) Old 04-11-2008, 07:27 AM Thread Starter
Paw
Pot/switch swap?
Hi there! Im currently fixing up my Jackson DK2 and want to get the best, cleanest sound possible from it. I have the stock pots in it right now but I have heard that the pots can make a big difference in tone so I wonder if I should change those out. I also want the bridge humbucker to coil tap together with the middle single coil in the 5-way selectors second position. The 5-way switch is stock, would I need to change that one too? Im gonna have a Duncan distortion in bridge, with Duncan classic stack humbucking single coils in middle and neck position.
This is how Id like the switching:
1st position: bridge humbucker
2nd position: bridge humbucker coil tapped + middle single coil
3rd position: middle single coil
4th position: middle single coil + neck single coil
5th position: neck single coil
As you understand Im new to this kind of stuff. Will any veterans reach out and help me out here?
Paw is offline
post #2 of 6 (permalink) Old 04-15-2008, 01:17 AM
Re: Pot/switch swap?
Sounds like standard Ibanez 5 way switching to me. a standard 5-way switch can do that as long as the humbuckers are capable of coil tap.
albee1952 is offline
post #3 of 6 (permalink) Old 04-15-2008, 04:28 AM
And humbuckers are capable of coil tap if they are 4-wire. Most modern ones I guess are capable, especially SDs.
Ibateur is offline
post #4 of 6 (permalink) Old 04-16-2008, 07:33 PM Thread Starter
Paw
Do I need any special pots to coiltap? thx for reply
Paw is offline
post #5 of 6 (permalink) Old 04-16-2008, 07:40 PM
elcid's Avatar
Nope, any pots will work if you tap your coils. The pickup selector will do that, not the pots
Check the Mega E witch from Stew Mac if you cant figure out how to get the Ibanez switch to do what you want
elcid is offline
post #6 of 6 (permalink) Old 04-18-2008, 06:13 PM Thread Starter
Paw
Great I have to do some studying then, or pay some dude to get it done. I put in another thread in the wiring section because I didn't know how to delete or move this thread, and he made a guide for me (see: http://www.jemsite.com/forums/showthread.php?t=76169) Anyone wants to add anything? Does it look okay?
Paw is offline
bridge hum , bridge humbucker , coil tap , duncan distortion , neck position
Jem Body Swap baldielocks Ibanez JEM, UV, JS & Other Signature Models 5 12-08-2004 12:33 PM
Swap A Les Paul For A 7620? Wound All Other Guitars (including Prestige) 4 10-16-2002 09:05 PM
Just did a Pickup swap, what to look for? Triangle Pickups & wiring 4 06-09-2002 01:08 PM
Which Pickups??? - Pickup Swap on my Ibanez RG550EX MrNiceguy87 Gear, Equipment, Recording & Off Topic 15 04-27-2002 07:56 PM
