Premium neck hole location - Jemsite
post #1 of 2 (permalink) Old 01-08-2018, 05:58 AM Thread Starter
Hi All
Does anyone know if the neck holes on the premium necks match either the japanese necks or the indo standard necks?
ive got a few premium necks, for example RG721 and RG921, and ive seen an S521 body available, which i'd likely sand down and fit a swanky veneer.
Are the necks likely to fit straight away? or am i likely to need to re-drill the neck?
Thanks
champ222 is offline
post #2 of 2 (permalink) Old 01-09-2018, 08:29 PM
Reviews: 120
Re: Premium neck hole location
The holes will likely need to be doweled and re-drilled, nothing hard. The heals may be an issue depending on the body. You may need to shave a couple mm out of the sides of the neck join.
LonePhantom is offline
premium neck holes
Damaged the hole surrounding my neck screw ferrule. monolithic87 Tech: Setup, Repairs and Mods 14 01-28-2016 12:55 AM
Project Strat repaint. F-hole or no f-hole? skins345669 Tech: Setup, Repairs and Mods 14 02-17-2009 04:41 PM
chambered/hollowbody maple top: hole or no-hole? rbjammin Tech: Setup, Repairs and Mods 2 06-28-2007 01:52 PM
Neck Shim - Proper location? YngVaiTriani Tech: Setup, Repairs and Mods 1 11-02-2001 02:50 AM
usrg-30 - the little hole in the neck... Eddie B All Other Guitars (including Prestige) 17 04-05-2001 08:32 PM
