Pro Rock'R to Edge - direct swap? - Jemsite
post #1 of 4 (permalink) Old 02-23-2004, 09:49 AM Thread Starter
Well the Subject line pretty much sums it up. I may be getting an old Rhandy Roads model and have a spare edge trem flying around here.
The thing that is of particular interest to me is the distance between the Anchors!
(Yes, I know the Pro-Rock'R isn't recessed, but that shouldn't be a problem)
horstausmforst is offline
post #2 of 4 (permalink) Old 02-23-2004, 10:46 AM
i think they have slightly different distances, but i'm not positive on that.
nuno is offline
post #3 of 4 (permalink) Old 02-23-2004, 12:04 PM
No go. The studs are farther apart, and the actual studs themselves are different. They don't have a knife edge. Instead they have a rounded cove, and the trem has an hourglass shaped insert. These are pretty bad for returning to pitch, but just fine if you block them or seat them against the body, and just do dives. I have had lots of these and still have 2 guitars with the pro-rockers. The best thing to do is clean the studs and the insert edges, and lube them with something heavy, like a silicone gel. WD-40 and other spray lubes are too thin.
It's actually an ingenious bridge design, like most Japanese product hardware it's over-designed and I love that. You can adjust everything, and then it all locks into place for stability and tone. And it's locking but you leave the ball ends on. (they've come full circle haven't they?) If it had knife edge inserts it would be on par with anything else out there.
frankfalbo is offline
post #4 of 4 (permalink) Old 02-24-2004, 08:14 AM Thread Starter
Thanks guys!
edge trem
WTB or Trade: A Chrome Edge, or swap for Cosmo Edge. clar-v-d Classified Ads: Guitars and Gear 0 11-17-2011 06:27 AM
Will a Gotoh Floyd fit as a direct swap for an edge pro do you know? themaidenmaniac All Other Guitars (including Prestige) 5 10-22-2010 09:14 PM
JS100 bridge swap??? Edge Pro / Edge Pro II n7uqa Ibanez JEM, UV, JS & Other Signature Models 8 06-04-2009 11:35 AM
