problem with licensed floyd rose - Jemsite
post #1 of 7 (permalink) Old 03-16-2004, 10:05 AM Thread Starter
hi,
I've got a jackson performer fitted with a licensed floyd rose.
The problem is that the 'nut' in which the tremelo arm screws in gets loose.It starts moving in its place if I move the tremelo arm.It comes out pretty easily if I try to unscrew it .
It's only my first year playing with a floating bridge type guitar.
I've tried putting nail polish and screwing it in or wrapping string or something around the grooves to make the nut fit in tight but it just comes loose.
Should I buy a new tremelo arm ? should I just change the full tremelo system ? Please help.
Thanks.
slayer is offline
post #2 of 7 (permalink) Old 03-16-2004, 10:17 AM
sad to be said but, i really think you better get an original Floyd Rose trem. your Jackson's got a cheap Floyd licensed, not even a Schaller-made one, and any efforts and tricks you'll do on that thing will be hopelessly useless.
you can find some original Floyds on ebay for relatively cheap, i guess, and it will fit perfectly your Jackson' trem's cavity. or you can even get an Ibanez Edge, but it may need some filing to fit the cavity.
nuno is offline
post #3 of 7 (permalink) Old 03-16-2004, 05:15 PM
hi,
If i undestand the problem, the same thing goes for a OFR, i have one and i know...put some "teflon" tape around the screw..the same you use in the water pipes in repairs..and that should help..it sure helps me..
"Teflon" is the word in Spanish..but i think is the same in English..right?
cheers
Vladdrac is offline
post #4 of 7 (permalink) Old 03-16-2004, 05:35 PM
Teflon tape - the white, thin stuff that goes around pipes right?
Longhair is offline
post #5 of 7 (permalink) Old 03-16-2004, 07:19 PM
Yes, that the one i´m referin to...
cheers
Vladdrac is offline
post #6 of 7 (permalink) Old 03-17-2004, 10:08 AM Thread Starter
thanks.
I think I'll try the teflon tape.
slayer is offline
post #7 of 7 (permalink) Old 03-17-2004, 12:54 PM
it all depends on what tremolo you got in your Jackson. if it's a Schaller-made Floyd, then ok, try with the teflon stuff, but if it's a Takeuchi-made or some Korean-made TRS-like crap, then, no hopes.
nuno is offline
floyd rose , floyd rose trem
FS: Floyd Rose licensed Tremolo ThreeMan Classified Ads: Guitars and Gear 3 03-25-2012 11:52 AM
OT: question about Floyd Rose original and FR licensed 7-string tremolo Santuzzo Tech: Setup, Repairs and Mods 0 04-08-2011 02:44 PM
Floyd Rose Licensed trems at Guitarpartsdepot StevenMikel Tech: Setup, Repairs and Mods 28 06-25-2009 05:36 PM
Floyd RoseŽ Licensed JacksonŽ Low Profile JT580 LP Double Locking 2-Point Tremolo neuro182 All Other Guitars (including Prestige) 11 07-08-2007 10:15 AM
will a Licensed floyd rose fit an OFR route? Van-Hannam Tech: Setup, Repairs and Mods 13 06-11-2007 04:21 PM
