Problem with Lo-Pro Edge - Jemsite
post #1 of 5 (permalink) Old 10-26-2017, 04:37 PM Thread Starter
Fam
Hi,
Every time I tune my JEM7V-WH (2001 model) and do a dive bomb, everything goes flat. And if I pull the bridge up after that, everything goes sharp (back to where it originally was). I have not faced this issue before. It started to happen after I had adjusted string height, so I'm guessing it could have something to do with that. What should I do?
EDIT:
I realize I wasn't being very clear. Here's an example of what happens:
-I tune the guitar normally
-Do a dive bomb
-After the bridge returns to parallel level with the body, everything has gone slightly flat
-And if I pull the bridge up, everything goes back to where it originally was (or very close to it, at least)
I purchased the guitar earlier this year, and I've had 0 issues with it thus far. Though one thing I guess I should mention; I don't think the locking screws inside the studs were tightened by the previous owner. When I adjusted the action earlier today, I was following the instructions Rich has on his site. The instructions say to loosen the locking screw. I'm pretty sure it was already loose (on both sides). I did tighten them when I was done adjusting the action, and I did not use any serious force.
Fam is offline
post #2 of 5 (permalink) Old 10-26-2017, 05:16 PM
Re: Problem with Lo-Pro Edge
Sounds like the knife edges of your trem may need sharpening.
IBANEZ RULES!! tech - setup
Rich'll show ya how^
Leviathus is offline
post #3 of 5 (permalink) Old 10-26-2017, 08:51 PM
1. Lube first - Chapstick
2. Lockdown procedure - IBANEZ RULES!! tech - setup
only file as a last resort.
Rich is offline
post #4 of 5 (permalink) Old 10-27-2017, 03:46 AM
Lock the nut screws.
vyansal is offline
post #5 of 5 (permalink) Old 12-23-2017, 03:53 AM
If it is not adjusted by you then you can go to where you have bought this guitar.
mixlikes is offline
lo pro edge
Edge Pro Problem pwsusi Tech: Setup, Repairs and Mods 2 12-27-2013 06:28 PM
Edge Pro problem Andrimner Tech: Setup, Repairs and Mods 12 10-13-2009 04:38 PM
Edge Pro Lo/Pro Whammy Problem Eddie_V_H Tech: Setup, Repairs and Mods 8 07-06-2006 01:17 AM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 09:59 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 02:43 PM
