problem with my universe - Jemsite
post #1 of 14 (permalink) Old 12-05-2005, 07:32 AM Thread Starter
hi there. i have a 7 string and a problem. The low H is making this "knack" sound, when i use my floydrose. when i open the stinglock to that sting (and the low E string) the problem dont exist, but i can let it be like that - cant use my wammy, when the lock is'nd locked ;-). hope one of you can help me. thanks michael
micdreyer is offline
post #2 of 14 (permalink) Old 12-05-2005, 09:06 AM
Re: problem with my universe
is it just hitting the pickup making the knack sound? Thats common place on some things, if you loosen the nut the string doesnt go quite as slack..............it could be anything honestly though but im assuming its just hitting the pickups
sniperfrommars1 is offline
post #3 of 14 (permalink) Old 12-05-2005, 09:20 AM Thread Starter
hi thee. thanks for your answere. but its not the pickups. its at the locksystem the problem is. and its only the low H there make this knack-noise. when i use my wammy, it give this short, fast knack, when i pull the wammy back.
post #4 of 14 (permalink) Old 12-05-2005, 10:36 AM
when you say H it reminds me of a brasseye sketch... do you mean B? since there is no H note..
anyway... is the bridge clipping the wood when you pull back? unlikely but its the only thing i can think of at the moment
Mr. S is offline
post #5 of 14 (permalink) Old 12-05-2005, 11:48 AM Thread Starter
hi there. no, it dont. the problem is where the string is hitting the stringlock. i thinks its where it makes the problem
post #6 of 14 (permalink) Old 12-05-2005, 04:34 PM
tried tightening the locking nut a bit more? ( do not overtighten,... it will break )
EL-CeeDee is offline
post #7 of 14 (permalink) Old 12-05-2005, 06:44 PM
Slightly offtopic here but my Swedish Sight Reading teacher told me that the note H is the same as something like B i think. I can't really remeber
Chud is offline
post #8 of 14 (permalink) Old 12-05-2005, 06:48 PM
i tune down to H too....
Ki swordsman is offline
post #9 of 14 (permalink) Old 12-05-2005, 06:53 PM
Guessing here, but is it possible you have the B string between the nut and the tuning peg over tightened? Kinda sounds like the further loss of tension when you drop the tremolo is causing the string nut to struggle to hold on to what may be too much tension. Maybe try loosening the nut, retune, then clampdown the nut. If that doesnt improve anything is it possible the nut itself is somewhat stripped from over tightening and its not clamping down properly?
eelblack2 is offline
post #10 of 14 (permalink) Old 12-05-2005, 07:27 PM
H = B in some European countries.
pawel is offline
post #11 of 14 (permalink) Old 12-08-2005, 02:48 PM
freaky.
So (anyone who uses H), if you were teaching someone a scale,
say A-min, what would you list the notes as? A-B-C-D-E-F-G-H?
RapIsNotMusic is offline
post #12 of 14 (permalink) Old 12-09-2005, 10:54 AM
Originally Posted by RapIsNotMusic
freaky.
A-H-C-D-E-F-G-A
pawel is offline
post #13 of 14 (permalink) Old 12-09-2005, 10:58 AM
hey there. it may be your lock nut assembly needs to be re tightened to the neck. it sounds crazy i know, but my 7620 had the same problem. the two screws that go through the neck itself may be loose. i used to get a knocking/popping sound when i used to use my bar as well
velocity is offline
post #14 of 14 (permalink) Old 12-09-2005, 12:18 PM
ive never come across a H note, but theory isnt my strongest point, ill have to ask my theory teacher...
Mr. S is offline
lock nut , locking nut , string nut
HELP PLEASE! UNIVERSE PROBLEM robhayes Ibanez JEM, UV, JS & Other Signature Models 2 09-01-2011 05:14 AM
Problem With Wiring Universe Mission1979 Pickups & wiring 3 01-16-2007 01:46 PM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
Universe question - grounding problem? Leary Ibanez JEM, UV, JS & Other Signature Models 7 09-10-2001 01:35 PM
