Problem with Trem Post 'mount' - Jemsite
post #1 of 10 (permalink) Old 09-21-2004, 10:02 PM Thread Starter
hi guys,
ive been restoring one of my much loved guitars - a Jackson Dinky that I've had for as long as i've been playing guitar (bout 10 years). Anyway, I recently attempted to put the tremolo back on and noticed that the Trem Post was just 'pulling' the plug straight out of the body... The other trem post mount is 'stuck' so im just wondering wheather i need to glue the thing back in - and what with? anyone else had a similar problem?
any help would be appreciated... cheers
dysfctn is offline
post #2 of 10 (permalink) Old 09-21-2004, 10:11 PM
Re: Problem with Trem Post 'mount'
Originally Posted by dysfctn
hi guys,
Had the same problem myself afew times in my life its common on jackson guitars as they dont have locking tremolo post. What happened is the post has vibrated a little with the swelling and shrinking of the wood, causing it to oval out or split the wood itself. It can be fixed with glue, but it depends on how large the problem is. Ive personally used various kinds of epoxy but im sure that Rich knows a better fix than me as usual. Sometimes this problem requires plugging the original hole and redrilling. But it should definitely be fixed,. Common problems associated with this are a horrible lack of tuning stability and tone, if it sounds fine, it could probably sound alot better
sniperfrommars1 is offline
post #3 of 10 (permalink) Old 09-21-2004, 10:14 PM
I used to use epoxy but I've been using wood glue lately.
If the anchor is loose it can be filled on the headstock side [the side that usually wears] with a good quality acetone based wood patch. It might not be loose, sometimes just pulling up on the trem can start to work out a normally tight anchor, in which case just pull it and use wood glue when you reseat it.
Rich is online
post #4 of 10 (permalink) Old 09-21-2004, 11:51 PM Thread Starter
heyguys, thanks for the quick response...
i'll try using some wood glue. but before i do, would you for any reason NOT use say a liquid nails product? its just that i have some already (sorry if that is epoxy - i aint a handy dude at all).
cheers again
dysfctn is offline
post #5 of 10 (permalink) Old 09-22-2004, 01:27 AM
I wouldn't, just because it's really thick. Doesn't mean it wouldn't work though.
Rich is online
post #6 of 10 (permalink) Old 09-22-2004, 01:48 AM
Im wondering why you avoid things that are thick like liquid nails? You have alot more experience with stuff like this so im just wondering. Ive used jb weld before and thats worked extremely well for me, although i dont know that I could get the old post out now, I dont have to worry about replacing them either.
post #7 of 10 (permalink) Old 09-22-2004, 02:06 AM
Just preference, Some of these can be pretty tough to press back in anyway so I prefer something thinner that flows better [and is much easier to clean up ]. I'd probably use JB before Liquid Nails and would probably be pretty good on loose anchors.
You can get any anchor out by locking a bolt in it and spinning it until it's free, then pull.
Rich is online
post #8 of 10 (permalink) Old 09-22-2004, 02:43 AM Thread Starter
Yeh good point. Well im glad it doesnt require major surgery!
cheers for the help guys!
dysfctn is offline
post #9 of 10 (permalink) Old 09-22-2004, 02:53 AM
I think Frank said he gives them a superglue bath to stiffen up the wood and to bond. There's probably as many preferences as there are products
Rich is online
post #10 of 10 (permalink) Old 09-22-2004, 03:05 AM
We use JB Weld at the shop I work in.
Mainly because the amp tech has like a life-time supply stashed in a drawer. :P
toshiro is offline
jackson dinky , jackson guitars , locking tremolo , playing guitar
Converting your Ring/guard mount pups to Direct mount RGTFanatic Tech: Setup, Repairs and Mods 77 04-08-2012 06:52 PM
Top mount Trem prydogga Tech: Setup, Repairs and Mods 1 06-29-2009 12:13 AM
replacing a rear mount nut with a front mount one Koss Tech: Setup, Repairs and Mods 3 08-31-2005 12:56 AM
Edge trem arm, with floyd mount? 1wi11 Tech: Setup, Repairs and Mods 0 05-17-2005 11:15 PM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
