Process to radius coiled stainless wire - Jemsite
post #1 of 9 (permalink) Old 10-21-2011, 03:39 PM Thread Starter
Hi Jemsiters,
I'm going to be refretting my practice neck soon with stainless steel. I've done some NS refrets which turned out well. I'm mainly wondering if anyone has had experience with stainless frets and a flat ibanez radius. I bought the wire from LMI, so it's coiled in about a 8" radius. Do I need a fret-bender? I'm not above buying or making the right tools. I've read as much as I can find about the stuff, and MindRiot over on Harmony Central opened up the coil by hand to match a 14" radius. I need a 16" radius. Compared to the NS, this stainless stuff is really really stiff and tough, so I'm looking for suggestions.
I have been doubting and putting off my refret since I read the recent thread where all the frets popped up in the middle:
http://www.jemsite.com/forums/f21/do...ight=stainless
Any thoughts?
Thanks,
Andrew
andrewgosline is offline
post #2 of 9 (permalink) Old 10-27-2011, 10:25 AM Thread Starter
Re: Process to radius coiled stainless wire
nobody eh? Well I'm thinking of chickening out and doing evo gold instead, which is still much harder than NS, but easier to work with than SS. I will have to save the 20 bucks of stainless wire for a later date
A
post #3 of 9 (permalink) Old 10-27-2011, 10:55 AM
Reviews: 98
Just over bend it to a radius tighter than what you need, then when you install it--it spreads in the slot.
AlaskaBat is offline
post #4 of 9 (permalink) Old 10-27-2011, 01:00 PM
this what you need but it is a little expensive.
http://www.stewmac.com/shop/Tools/Sp...xst=3&xsr=7963
http://www.stewmac.com/shop/Fretting_supplies.html
j.arledge is offline
post #5 of 9 (permalink) Old 10-28-2011, 09:46 AM Thread Starter
Thanks for the suggestions. Have either of y'all done an SS install and can comment on the differences??? I'm quite familiar with the NS process. My trolling leads me to believe that over-radiusing can lead to the fret popping up in the middle, as I linked to above. The fretbender can't 'unbend' wire. So you're suggesting hand straighten the wire, then use the fretbender? I'd thought of that, but it seems a little like overkill. Also stewmac really only sells tools for NS wire. Who knows if that thing's plastic crank and brass roller can hold up to something like SS with a much higher elastic modulus.
Either way, I'm reconsidering the SS in stall for Evo as I already posted.
post #6 of 9 (permalink) Old 10-28-2011, 09:48 AM
Reviews: 17
Please show the process of your re-fret
Speedabob is offline
post #7 of 9 (permalink) Old 10-28-2011, 11:14 AM Thread Starter
Sure thing
post #8 of 9 (permalink) Old 10-28-2011, 01:52 PM
Reviews: 17
Excellent ! Looking forward to it
post #9 of 9 (permalink) Old 10-28-2011, 01:54 PM
Unlike nickel silver, the radius of stainless steel wire needs to match the fingerboard. It isn't as soft as ns and will not conform to the fingerboard radius. A shop I worked at bought a pound of it in straight lengths from Allparts or Stew Mac and used it to fret a new build. It was the one and only time it was used, and we had all of the right tools. That tube of wire now rests in a corner somewhere in the shop. I guess some people don't want to go through the learning curve it requires.
jgriffin is offline
refretting , stainless steel frets
PG style coiled cable?? mattacuk Gear, Equipment, Recording & Off Topic 2 07-10-2010 03:02 PM
Is there a specific type of wire needed to wire a guitar? IBNZ_RG Pickups & wiring 6 04-18-2010 01:48 AM
WTB: Bullet Coiled Cable jordanstreet Classified Ads: Guitars and Gear 0 03-26-2009 07:46 PM
Rewiring Job: What wire is good wire? Gex Tech: Setup, Repairs and Mods 3 06-11-2005 01:01 PM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an floydJ Tech: Setup, Repairs and Mods 3 08-07-2001 12:59 PM
