Proyect - Strip an RG270 using chemicals/Sanding - Jemsite
post #1 of 45 (permalink) Old 02-17-2006, 11:40 PM Thread Starter
Hi, iīm starting my project changing the finish on a RG270 ive got recently. Its de 1995 the one with the maple neck.
I started sanding down the finish, but after an hour got tired and realized ii`ve achieved the 15% of the job... so i decided to try chemical stripping. I`ve readed the tutorial on projectguitar.com about all the methods on stripping the finish, and i`ve seen stripping with chemichals the factory finish isnīt the best method (but i didnīt knew why until now).
Iīve started with a body with the translucent finish off (by sanding like i said), after the 5th coat of paint remover (and about 2-3 hours half an hour between each coat) it started to came off a littel bit (as i said now i know why the factory finish should be stripped by other method)... but the color started to come out... and what i see its the primer (i think) i havent seen wood yet.
I`m still in progress ill let you know how it goes tomorrow... here are some pics
i`m not shure wich finish it will have... i`m between tung oil with veener (2 tones finish top clear back dark or something like that and to change the hardware to gold... or something like the jem10 (the strange black one there is a product for boats and trucks that looks alike)... weel see...
ANY IDEAS??
before
after the sanding and 1 coat of chemical stripp
cheers
jlander is offline
post #2 of 45 (permalink) Old 02-18-2006, 10:42 AM
Re: Proyect - Strip an RG270 using chemicals/Sanding
The fastest way I can think of to strip down one of those is a heat gun. Mind you, the part that chemical strippers have a hard time with is really the clearcoat than anything else. Good luck with your project.
buddroyce is offline
post #3 of 45 (permalink) Old 02-18-2006, 11:24 AM
i tried stripping off my yamaha pac012 (its in red), the laquer came off very easily, the red paint also came off easily, but after that, there is a silver coating, which it seems to be impossible to strip off with the chemical, wonder what is that?
Jing is offline
post #4 of 45 (permalink) Old 02-18-2006, 11:48 PM Thread Starter
yes its right the problem is the clear coat... is hard as rock... the parts where there is only paint (tremolo routing in example) comes very easy... but i have to say after 5 coats of paint remover it started to come a little bit... i think about 8 to 10 would do it, but i dont have so much patience, so i grabbed the sand paper and started the sanding again... it was easy (sort of).. in about half an hour i had the front of the body sanded... i think the chemicals helped... ill post some pics later...
about the silver coat that jing says in his yamaha pacifica, it is on my RG too... i think is the primer they apply to the body before painting it...
cheers... back to sanding
jlander is offline
post #5 of 45 (permalink) Old 02-19-2006, 09:18 AM
I've heard some people will cover the guitar with paint remover and seal it up in a garbage bag for a couple of days. Supposedly that will get the job done. I just stripped an RG with a heat gun and it was easy.
Rotti is offline
post #6 of 45 (permalink) Old 02-19-2006, 09:28 AM Thread Starter
well the problem with the heat gun for me is that in venezuela you cant buy it in the store next to you, and they are expensive... thats why im doing it by other methods..
well like i said, the proyect is doing fine, i stripped the front and a side in the guitar, here are the pics... i sttopped because i ran out of sand paper and got tired too ..
Finally!!!! some wood
the top is done
the side too... got tired
cheers
jlander is offline
post #7 of 45 (permalink) Old 02-19-2006, 10:59 AM
Cool, looks like you have a fairly nice peice of wood too. No knots or anything. Good job.
Rotti is offline
post #8 of 45 (permalink) Old 02-19-2006, 09:50 PM Thread Starter
new advance... about an hour and a half it went harder....
this is the advance... the inside parts are harder than what i though...
here is a preview of how it could look, im starting to think abpout leavnig it natural or with a bit of translucent yellow... we`ll see...
thanks
the weekend is over, back to work on monday
jlander is offline
post #9 of 45 (permalink) Old 02-19-2006, 09:57 PM
Looks like it's going well. Nice job!
JM5150 is offline
post #10 of 45 (permalink) Old 02-22-2006, 05:43 PM Thread Starter
more work...
i hope another day and the paint is removed... only left the final sanding 400 1000 1500 sand paper for finish...
then to decide what to do with the finish???
see ya
jlander is offline
post #11 of 45 (permalink) Old 02-23-2006, 09:57 AM
Awesome... im in the middle of doing the same thing to a japanese Jackson thats been refinished...
only problem is whoever did the refin sucks, and it seems they painted over the original paint, so i have a ****load of sanding ahead of me before i see alder... (and damn it damn better be alder as its supposed to be )
marianozz is offline
post #12 of 45 (permalink) Old 02-23-2006, 12:52 PM
rgr
Do you have a sander or are you doing it by hand? Props to you if you are doing it by hand. BTW, 220 grit is smooth enough before the finish, no need to go even go to 400. Fo final sanding after the finish, that's where you use the really fine grades.
rgr is offline
post #13 of 45 (permalink) Old 02-23-2006, 02:30 PM
I used a RG270 as my first swirl project. I was suprised by the grain that was on it.
Andy43 is offline
post #14 of 45 (permalink) Old 02-23-2006, 06:36 PM
What kind of trem does it have on it?
Rotti is offline
post #15 of 45 (permalink) Old 02-23-2006, 07:09 PM Thread Starter
ok, im doing it by hand... thats why its taking so long.. but im having a good time doing it... (but wont do it again by hand...).. it has a single locking ibanez floyd... it sucks let me tell you... ill change it later... as it is my backup guitar this proyect can take long... do you know why it cant stay in tune?? are the locking nuts?? the floyd?? both?? if i change it will work with the same nuts??
still wondering on what finish to use... any suggestions????
cheers
jlander is offline
clear coat , edge bridge , locking nut , locking nuts , maple neck , swirl project , tung oil , yamaha pacifica
Does Anyone Use Strip Connectors? Laobi Pickups & wiring 11 12-11-2013 08:10 PM
Using chemical to strip paint TWJ Tech: Setup, Repairs and Mods 4 05-07-2007 10:43 PM
what do I use to strip finnishes gunkungfu Tech: Setup, Repairs and Mods 8 06-13-2005 01:44 AM
How do I strip THAT? Petie Tech: Setup, Repairs and Mods 7 05-03-2003 01:10 AM
What Should I use to strip the paint? - Off of this cheap RG Contra Tech: Setup, Repairs and Mods 14 05-03-2002 04:06 AM
