Question about drop c tuning? - Jemsite
post #1 of 6 (permalink) Old 04-11-2004, 01:38 PM Thread Starter
I use gauge 9 strings for standard tuning ( e, a, d, g, b, e ). If I want to play in d I tune all the strings down to ( d, g, c, f, a, d ). Instead of tuning all the strings down to a c tuning I think alot of bands just simply tune the d string to c to get ( c, g, c, f, a, d ). Is it better to use the same gauge string when tuning the fat d string down to c or do you use a fatter gauge for just that one string compared to the others.
big h is offline
post #2 of 6 (permalink) Old 04-11-2004, 01:52 PM
I usually use guage 10, but one of my guitars is tuned to drop C (all down a tone but the low e down 2). For that I use guage 12 and they are still noticeably looser than 10s are in standard tuning. Unless you want the effect of really loose strings, I suggest you experiment with some heavier guages.
Algiman is offline
post #3 of 6 (permalink) Old 04-11-2004, 04:04 PM
Hello!
Here's my addition to your topic:
For regular E tuning I use 009-011-016-026-036-046.
For regular D tuning I use 010-013-017-030-042-052.
For drop C: I use the 010-052 set, but I change the 052 on the E string to a 056, tuned to C.
This is the common "heavy bottom, light top" string sets.
For the 7th string, I use 059 in B, and 074 in A.
Hope it helps
Tony
tony777 is offline
post #4 of 6 (permalink) Old 04-11-2004, 05:35 PM Thread Starter
So what your saying is you can buy a 10-52 set but you don't use the 52 string and chance it for a 56, ok. A follow up question is it good for your guitars neck to have heavy bottom with light top combos. The tension would be more uneven than a regular gauge set and could this be bad for the neck somehow making it warp possibly? Thanks for both your feedback. I can't get over a 76 gauge string, that's a FAT string!
big h is offline
post #5 of 6 (permalink) Old 04-12-2004, 07:44 AM
I've been using light top,heavy bottom on my rg560 since '93, and it still plays great, so I don't think the neck will suffer from that.
yep, that's fat but it doesn't woooaaaauuuuww, like thinner strings does in low A tuning. (though it is a 074) and it's possible to intonate on a 25,5 scale guitar, which is a major problem with 059 and 066 gauge in low A.
Tony
tony777 is offline
post #6 of 6 (permalink) Old 04-14-2004, 12:41 PM
I use drop-C exclusively, and use the bottom five of the Ernie Ball 11-48 set, with a separate 60 for the low C. I should also mention that I pick really hard, so anything lower in gauge and it goes sharp and out of tune all the time.
failsafe306 is offline
ernie ball
Tuning question! Is drop D hard on a trem using fine tuners? HendrixToTheEnd All Other Guitars (including Prestige) 8 02-03-2008 08:16 PM
Drop tuning RG462 Tech: Setup, Repairs and Mods 5 08-11-2007 03:26 PM
Drop C tuning with 9's JoeJoe Tech: Setup, Repairs and Mods 14 06-25-2006 11:06 AM
Drop D-Tuning metallica81788 Tech: Setup, Repairs and Mods 2 05-26-2006 07:56 PM
Drop D Tuning pigdestroyer Tech: Setup, Repairs and Mods 2 08-13-2002 02:03 PM
