question about a fret that's not seated right - Jemsite
post #1 of 14 (permalink) Old 12-31-2012, 05:35 AM Thread Starter
Question question about a fret that's not seated right
Hi,
I just noticed on my new RG827 Premium there is a fret buzz on the 7th string when fretted on the 1st fret, so I took a look at the 2nd fret and saw it's not seated into the wood all the way, from the end of the fretboard I can actually see a tiny crack.
Is this something that can be fixed easily by hammering the fret? or will the fret keep popping out over time even if it's hammered back in?
EDIT:
here's some pics:
Thanks,
Lars
Santuzzo is offline
post #2 of 14 (permalink) Old 12-31-2012, 06:53 AM
Re: question about a fret that's not seated right
I would hammer it in (carefully and "properly") and see where it goes from there.
The other option is to pull the fret, fix the crack, re-saw the slot and re-apply the fret. If you don't know how to do this, I would suggest the first option first. I don't know how bad the crack is. Also, pulling frets could damage the wood even more and if that happens, it will be suxorz for a bit.
Ibateur is offline
post #3 of 14 (permalink) Old 12-31-2012, 07:09 AM Thread Starter
Thanks. I just added some pics.
Santuzzo is offline
post #4 of 14 (permalink) Old 12-31-2012, 09:34 AM
Reviews: 14
You stated the guitar was new. This seems to be a defect related to workmanship and should be covered under warranty. It is possible to re-seat the fret, but you may want to consider having Ibanez correct the problem.
Pamanagm is offline
post #5 of 14 (permalink) Old 12-31-2012, 10:35 AM
Reviews: 37
I would send it back to dealer for warranty.
If not use a brass fret setter and hammer it in on the edge.
andrewsfury is offline
post #6 of 14 (permalink) Old 12-31-2012, 10:36 AM Thread Starter
Thanks.
Yes it's a new guitar, but I was planning to bring the guitar to a tech next week for a pick-up swap anyway, so I will let him repair this for me.
If this is an easy fix, it's not worth sending the guitar back to the dealer/distributor, etc.
But once the fret is tapped back into place, will it stay there? or are chances that it will keep coming back out over time?
Santuzzo is offline
post #7 of 14 (permalink) Old 12-31-2012, 10:37 AM Thread Starter
Originally Posted by andrewsfury View Post
The bad thing is is that they leveled the frets like that and if you go down with it it will cause buzzing.
I actually think the fret was in place and came out AFTER leveling, since it's too high. I had not noticed this if it wasn't for the fret-buzz I'm getting on the lowest string when fretted on the 1st fret.
Santuzzo is offline
post #8 of 14 (permalink) Old 12-31-2012, 12:18 PM
Can't you just take it to any Ibanez dealer with a luthier and have them fix it under warranty?
Swirltop is offline
post #9 of 14 (permalink) Old 12-31-2012, 12:48 PM
in holland, that would be a lol.
Ibateur is offline
post #10 of 14 (permalink) Old 12-31-2012, 12:56 PM
Oh lol didn't notice this was in Holland!
Swirltop is offline
post #11 of 14 (permalink) Old 12-31-2012, 04:01 PM
(Swirltop Heehee....)
Hey Santuzzo, just have the guy fix hammer it in for you (hopefully not directly with a carpenter's hammer). It could very well pop out again, but if that happens, you can have the guy pull the fret, maybe shape it, and glue it back. Assume it won't simply for the sanity. He could repair that "crack" (<--- looks less than minor on the pics to be honest) at that time.
Ibateur is offline
post #12 of 14 (permalink) Old 01-03-2013, 09:31 AM Thread Starter
Thanks !
Santuzzo is offline
post #13 of 14 (permalink) Old 01-11-2013, 06:50 PM Thread Starter
I brought the guitar to my tech today, and he said the fret will be an easy fix, he will glue it, and it should be all good then.
He said it should be a permanent solution, the fret might only pop out again if the guitar would be exposed to extreme temperatures, like in super hot summer.
He will also install the CL/LF set !
I will post back when I get the guitar back from the tech.
Santuzzo is offline
post #14 of 14 (permalink) Old 02-08-2013, 07:08 AM Thread Starter
Update:
I just got my guitar back from the tech.
The fret is repaired, he filled the tiny gap with superglue so the fret will stay put and then leveled the fret, so there is not buzzing.
So, all is good now!
Also: the guitar sounds great with the new PUs!!!
Santuzzo is offline
fret buzz
Fret wire question kmanick Ibanez JEM, UV, JS & Other Signature Models 0 08-05-2008 07:44 PM
24 Fret Tuning Question! Schwarzwind Tech: Setup, Repairs and Mods 40 09-03-2007 12:33 PM
Fret question mi2tom Tech: Setup, Repairs and Mods 6 02-09-2007 11:28 PM
ESP fret question Chud All Other Guitars (including Prestige) 5 03-23-2006 01:58 PM
Practicing while seated - Bobby O teaches a good lesson kennydoe Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 23 07-29-2001 01:08 AM
