Questions about swirling a JEM 7DBK - Jemsite
post #1 of 6 (permalink) Old 01-06-2012, 10:46 PM Thread Starter
So I have a Jem 7 dbk (the one with the bumpy surface)... I am not a fan of the plain black surface, so I was thinking about swirling it... Here are the questions:
1)Can you swirl a guitar with a 'bumpy' surface?
2)Should I put primer coat on the bumpy finish?? or can i just swirl the paint on top of the black finish?
3)Can you clear coat the 'bumpy finish' when it is done with the swirl??
4) is primer thick?? will it make the bumpy coat more rugged??
Would I be better off buying a replacement jem body, and just swirling that?? I want to swirl it with the bumpy surface, as i think it would be unique, but I would like to know if thats possible. Thanks!
Also where could I buy a replacement jem body, if that were the case. Cheers!
shono is offline
post #2 of 6 (permalink) Old 01-06-2012, 10:50 PM
Re: Questions about swirling a JEM 7DBK
buy a new body, as not desirable as the DBK is, its still easier to sell without the swirl.
And the only way to do it right on that finish is to strip it.
ibanezcollector is offline
post #3 of 6 (permalink) Old 01-07-2012, 04:00 AM
bumpy swirl sounds bad.
nafigator is offline
post #4 of 6 (permalink) Old 01-07-2012, 06:51 AM
I'd just start over all together.
The inlays on the DBK are dull anyway.
Just leave it and build a different guitar.
Sell it if you don't like it.
sebastian is offline
post #5 of 6 (permalink) Old 01-07-2012, 06:00 PM
Reviews: 4
Hey Shon!! (it's Frank)
I think that's a neat concept for swirling on a surface like the Dbk! While I think it is obviously a lot easier to swirl on a brand new blank body, you may still have a chance with the dbk.. here is what I might do if I were you: I could maybe sand the finish to make it a little rough for the finish to properly set on the body... I'm pretty sure you would need to sand past the shiny clear-coat for the paint to "stick" properly.
Another option, if you are looking at the body mostly for a novelty-value kind of thing and don't want to risk messing up a good body, there are a few cheap Jem "kit's" out there. These are kinda low-end and not really appreciated by many here, but it could be a good alternative for your situation.
Good luck!
fwd0120 is offline
post #6 of 6 (permalink) Old 01-07-2012, 10:10 PM Thread Starter
Good luck!
cheers man, I appreciate your in depth answer... I came to conclusions about my decision now, and will keep the DBK as it stands. It is a great guitar as it is, and probably isn't worth the hastle anyway. I will just keep the idea for a project in the future.
shono is offline
jem swirl
Two questions: Inserts and swirling. Ad_Astra Tech: Setup, Repairs and Mods 2 02-03-2009 11:22 PM
Swirling :) fettouhi Tech: Setup, Repairs and Mods 4 03-21-2007 06:17 AM
Swirling QA barbarelaxe Tech: Setup, Repairs and Mods 19 12-03-2006 06:21 AM
Tut for guitar swirling here ddragon64 Ibanez JEM, UV, JS & Other Signature Models 53 02-01-2005 11:51 AM
Swirling an RG? Swirly Tech: Setup, Repairs and Mods 3 04-04-2003 12:51 PM
