Questions - Installing Trem Stud Inserts - Jemsite
post #1 of 9 (permalink) Old 04-04-2013, 05:58 PM Thread Starter
webmaestro's Avatar
Getting an aftermarket body that's routed for a Lo Pro Edge. I have two questions about installing the trem stud inserts:
1. Do I use glue, or just press them in dry? If glue, what brand/kind?
2. I don't have access to a drill press. Is it okay to hammer them in? Obviously, I'll be very careful and use a wood block, but let me know if there are any tips or tricks to doing this properly.
That's it! Thanks in advance.
webmaestro is offline
post #2 of 9 (permalink) Old 04-04-2013, 06:06 PM
RGTFanatic's Avatar
Re: Questions - Installing Trem Stud Inserts
Tapping them in works great....... a little titebond wood glue goes a long way!!
Be sure to inspect the bores thoroughly before installing the inserts. You wouldn't believe how often the bores are out of round or have cracks between them and the block cavity.
RGTFanatic is offline
post #3 of 9 (permalink) Old 04-04-2013, 06:11 PM Thread Starter
webmaestro's Avatar
Thanks for the advice. I also just happened to find another thread here where someone asked a very similar question. Forum search fail on my part
Seems like a bit of glue might also act as lube... to help them slide in easier.
Wow, that got weird...
post #4 of 9 (permalink) Old 04-04-2013, 06:16 PM
RGTFanatic's Avatar
LMAO!!!! nothing wrong with a little lube now and then, but real men go at it dry!!!!!
Anyway, you'll see a small hole at the bottom side of the insert. only use enough glue to get a little in the hole. when it dries, it will act like a lock for the insert. If you use too much, it will act like a lock on the stud....... not good.
post #5 of 9 (permalink) Old 04-04-2013, 07:22 PM
Reviews: 4
Well, I was going to insert my two cents, but it looks like ryc already answered what I would've said... but I can't read this thread now without cringing a little bit...
fwd0120 is offline
post #6 of 9 (permalink) Old 04-04-2013, 07:31 PM
Reviews: 120
Well that went wrong really quickly!
LonePhantom is offline
post #7 of 9 (permalink) Old 04-04-2013, 08:05 PM
RGTFanatic's Avatar
Just par for the course, I'd say
post #8 of 9 (permalink) Old 04-04-2013, 08:32 PM
If I remember correctly the hole is 11mm
sebastian is offline
post #9 of 9 (permalink) Old 04-04-2013, 08:53 PM
RGTFanatic's Avatar
I hope not, the anchor is only 11.04mm OD. IIRC, the bore had to be like 10.75mm (27/64") to get a good tight fit. Of course with more lube...........
trem stud inserts
install Stud inserts for edge trem ibanguitar All Other Guitars (including Prestige) 10 08-08-2019 12:00 PM
Installing trem stud anchors keith_remy Tech: Setup, Repairs and Mods 4 01-14-2011 06:31 AM
Stud inserts, anchors ibanguitar Tech: Setup, Repairs and Mods 5 02-04-2010 02:54 PM
Any experience installing stud inserts? djrjems Tech: Setup, Repairs and Mods 7 05-18-2008 08:22 PM
problem with my stud inserts!Help jemke Tech: Setup, Repairs and Mods 15 11-21-2002 09:18 AM
