R43 Nut - Jemsite
post #1 of 3 (permalink) Old 07-14-2017, 07:56 AM Thread Starter
R43 Nut
Hello,
i have a JEM 555 build 1994 in Korea. I want to change the Lo-TRS II Trem to a GOTOH GE1996 and i saw that my locking nut has heavy scratches on the frist 3 strings and so i want to change it too. The Nut is locked by two screws from the back of the neck and " R43 " is stamped in. I don`t know if my neck has a 400mm or 430mm radius.
And here are my questions:
Is there a sparepart that is compatible?
perhaps with better Quality?
Is the locking nut from the JEM7V compatible?
Thanks for your answer,
aulbaer
aulbaer is offline
post #2 of 3 (permalink) Old 07-14-2017, 10:15 AM
site founder 0% owner
jemsite's Avatar
Re: R43 Nut
1994 has the JEM neck profile 430mm radius. 43mm width.
You'll need to check the spacing of the current nut if it matches the TopLok nut holes or fill/redrill and/or use the top mount screw version.
jemsite is offline
post #3 of 3 (permalink) Old 07-18-2017, 03:54 PM Thread Starter
Re: R43 Nut
Hello, thanks for the information about the neck.
i will order a new nut and measure it out.
aulbaer is offline
jem 555 , lockin nut , r43
Weird metal plate at nut (nut buzz) SRS94 Tech: Setup, Repairs and Mods 8 04-29-2013 08:49 AM
Info on a R43 Nut ? shepard0620 Tech: Setup, Repairs and Mods 7 04-02-2008 11:08 AM
Any tips for lubricating your nut? (An RGA guitar nut that is) RG1820X All Other Guitars (including Prestige) 34 08-14-2007 12:29 PM
Nut Height. Too high? Rich, do I have to file the nut base? MetalZone Tech: Setup, Repairs and Mods 7 08-21-2006 02:40 PM
Change Ibanez 550 neck locking nut for bone nut Deep Tech: Setup, Repairs and Mods 6 08-30-2004 10:14 PM
