Real quick..mm"s *converted to 50th's of an inch.. - help me - Jemsite
post #1 of 4 (permalink) Old 12-21-2000, 08:07 PM Thread Starter
I wanna check my pick-up highth and all I have with me right now, is a little ruler that measures in increments of *10's and 50's of an inch. *
Someone please get me close....I think the Jemsite says between 1.6 and 2.0 mm's.....
Thanks fellas
jc
badwamajama is offline
post #2 of 4 (permalink) Old 12-21-2000, 08:35 PM
I use the 1.5mm allen wrench that comes with the guitar. I adjust until it touches the string and lower it 1/4 turn. I use the same tool to adjust string height at the 24th fret and to adjust bridge angle. Works like a charm.
J>
Vaibanez is offline
post #3 of 4 (permalink) Old 12-22-2000, 02:41 AM
rgr
1mm = .039", to convert divide inches by 25.4 or multiply mm by 25.4, therefore 1.6mm = .063" or 1/8" and 2mm = .079".
Hope this helps,
Roger
rgr is offline
post #4 of 4 (permalink) Old 12-22-2000, 11:59 AM
I don't think you need to be all that accurate.
A visual reference should do the trick well enough.
Steve
ripl3y is offline
allen wrench , bridge angle
I've been converted. JS FTW. musicmang3 Ibanez JEM, UV, JS & Other Signature Models 9 12-19-2011 05:29 AM
has anybody converted a strat body to aanj? eddie stan halen Tech: Setup, Repairs and Mods 2 05-25-2009 08:21 AM
Wiring issue. Probably easy to fix. Help me real quick GuitarEvan07 Pickups & wiring 3 12-21-2008 05:00 AM
Another one converted.. 56k Stay Away ibanezcollector All Other Guitars (including Prestige) 9 01-13-2007 12:26 PM
Amps: Have i been converted? darren wilson Gear, Equipment, Recording & Off Topic 43 04-19-2003 07:36 PM
