Refinishing/coating Edge/Lo-Pro Trem? - Jemsite
post #1 of 11 (permalink) Old 08-22-2011, 02:41 PM Thread Starter
If you were to take either of the two, and get them either powder coated or painted, would that have an impact on how they go together/work? or are the tolerances enough that there's room for the extra fractions of a mm that would be added to the overall size?
i only ask, because they are really limited to black, cosmo black, chrome or gold. and i know one of those colours will pretty much go with whatever it is you want to do. but what if (just to be way out and wacky!!) you decided you wanted ur trem to be LNG (for want of a better colour choice off hand)?!
rickybaby1985 is offline
post #2 of 11 (permalink) Old 08-22-2011, 03:16 PM
Re: Refinishing/coating Edge/Lo-Pro Trem?
Not gonna happen.
musikron is offline
post #3 of 11 (permalink) Old 08-22-2011, 03:43 PM
Reviews: 11
Originally Posted by musikron View Post
Not gonna happen.
right.
no ones ever done that before.
works just fine. However, doing the saddles requires electroplating, powder coating will be too thick.
linuxpenguin is offline
post #4 of 11 (permalink) Old 08-22-2011, 04:22 PM
Reviews: 98
There are other colors out there, too--just harder to find. There is a white powdercoated LoPro that came on a few RGs, as well as the violet chrome LoPro I got from Ryc.
AlaskaBat is offline
post #5 of 11 (permalink) Old 08-22-2011, 04:31 PM Thread Starter
any pics of the violet chrome? that sounds yummy!
post #6 of 11 (permalink) Old 08-22-2011, 04:44 PM
I wouldn't have it powder coated or painted. Way too thick. I'd look for someone who does work on guns. They offer all sorts of decorative plating finishes.
Takin' a Ride is offline
post #7 of 11 (permalink) Old 08-23-2011, 12:02 AM
I would look into anodizing as another option. This depends on what kind of metal the bridge is made out of though. This can be done for fairly cheap by a professional or you'd be able to learn how to do it by yourself.
xXLinkageXx is offline
post #8 of 11 (permalink) Old 08-23-2011, 04:40 AM Thread Starter
im fairly sure anodising can only be to done aluminium?! and the trem blocks are steel?
post #9 of 11 (permalink) Old 08-23-2011, 07:27 AM
"Anodic films are most commonly applied to protect aluminium alloys, although processes also exist for titanium, zinc, magnesium, niobium, and tantalum. Iron or carbon steel metal exfoliates when oxidized under neutral or alkaline microelectrolytic conditions; i.e., the iron oxide (actually "Ferric hydroxide" or Hydrated iron oxide, also known as rust) forms by anoxic anodic pits and large cathodic surface, these pits concentrate anions such as sulfate and chloride accelerating the underlying metal to corrosion. Carbon flakes or nodules in high carbon steel(e.g. cast iron) may cause an electrolytic potential and interfere with coating or plating. Ferrous metals are commonly anodized electrolytically in Nitric acid, or by treatment with Red Fuming Nitric Acid, to form hard black Ferric Oxide. This oxide remains conformal even when plated on wire and the wire is bent."
post #10 of 11 (permalink) Old 08-23-2011, 07:58 AM
Here you go, check this out:
http://www.houtsenterprises.net/index.html
post #11 of 11 (permalink) Old 10-14-2011, 09:58 AM
What is the factory finish? How are they doing it. Anyone know? powder coat...anodized...??
sssteve72 is offline
How to remove ZR trem, destroy it, then install Edge trem? bdk Tech: Setup, Repairs and Mods 16 07-25-2010 01:33 PM
Cosmo black finish wearing off Original Edge. Will refinishing work? Stygian All Other Guitars (including Prestige) 10 02-12-2008 05:16 PM
Refinishing 7VWH gold trem BigShred Ibanez JEM, UV, JS & Other Signature Models 26 04-17-2007 08:41 AM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 03:18 PM
Refinishing Advice Anyone? - Body Refinishing ScottB Tech: Setup, Repairs and Mods 4 12-16-2001 06:25 PM
