Refinishing a guitar - Jemsite
post #1 of 2 (permalink) Old 04-15-2004, 10:42 AM Thread Starter
I'm thinking of refinishing a guitar with a material finish. What I want to know is:
Is it possible to do a good job with a brush rather than shooting the finish. I would just sand in-between each of the coats? Also, I'm only planning on doing the front since this is a neck-thru.
Any suggestions, or should I just have someone do it for me?
Thanx,
Peter
lhrocker is offline
post #2 of 2 (permalink) Old 04-15-2004, 07:15 PM
Yes, it is posible..but you have to spread the coats even and have to sand alot to be sure that you donīt have some "depth" or "channel" spots
You start with a 300 for the first part of the sealent part and slowly, while you are geting thicker coats of it..move up on 400, 600..then put the clear and work from 400 grit up until you reach 1200-1500 and your done..
Sound more easy than actually is ..but can be done..all you need is patience..
Iīm working in a yamaha RGX110 with a fabric and using this method have been very slow..but i wanna do it right..when i get this finished i put a picture..
hope this helps you
cheers
Vladdrac is offline
yamaha rgx
Guitar neck refinishing help Lydok Tech: Setup, Repairs and Mods 14 04-16-2014 09:22 PM
Guitar refinishing worldrecordholder Tech: Setup, Repairs and Mods 89 08-30-2013 10:28 PM
Guitar Refinishing- Using Enamel? WholesaleWNG All Other Guitars (including Prestige) 5 06-22-2012 01:29 PM
Guitar Refinishing Projects courtney2018 Tech: Setup, Repairs and Mods 8 06-16-2007 02:03 PM
Guitar Refinishing...Car Sprayers? keith Tech: Setup, Repairs and Mods 11 04-21-2003 09:58 PM
