Removing an Ibanez LoPro Edge Arm holder - any tips? - Jemsite
post #1 of 10 (permalink) Old 03-15-2016, 01:38 PM Thread Starter
I grabbed a couple OFR push-in bars (which are awesome) to replace the standard Ibanez arm holders on my last two edge-equipped guitars, and I can't get the damned things off. The nut on the back unscrews easily enough, but the arm holder itself won't budge. Are they using a stronger lock-tite these days or something? Anyone have any other tips - heat it? Soak it in some sort of solvent? I'd really love to switch to (which I consider a) better arm holder, but I'd rather not irrepairably damage the trem to do so - if need be, I'd rather just hope that an OFR is a drop-in replacement, and swap out the whole unit. Thanks!
Drew is offline
post #2 of 10 (permalink) Old 03-15-2016, 09:18 PM
metalhead52's Avatar
Re: Removing an Ibanez LoPro Edge Arm holder - any tips?
Pretty sure the arm holder unscrews from the body of the trem as well. That is what the screwdriver slots are for on top of it. The nut just locks it in place.
metalhead52 is offline
post #3 of 10 (permalink) Old 03-16-2016, 09:54 AM
There is probably some Loc-tite in there. Heat the arm holder with a soldering iron maybe?
Takin' a Ride is offline
post #4 of 10 (permalink) Old 03-16-2016, 12:26 PM Thread Starter
Yeah, the advise I'm getting esewhere is apply heat to break down the loctite and then go at it, counter-clockwise from the top, with vise grip pliars (since I don't have a perfectly sized screwdriver, and it's less likely something will slip this way).
I'll pass along an update over the weekend.
Drew is offline
post #5 of 10 (permalink) Old 03-16-2016, 12:31 PM
I hope you mean clockwise, counter will tighten it. And channel lock pliers will have much better bite than vice grips. Stay away from the barrel and only use the tip where it's solid.
Rich is offline
post #6 of 10 (permalink) Old 03-17-2016, 12:53 PM Thread Starter
Thanks Rich! So, clockwise looking down from the top, counter-clockwise looking up from the bottom? Turns out I'm bad with tool names and the set I was thinking of IS channel lock.
Drew is offline
post #7 of 10 (permalink) Old 03-17-2016, 01:18 PM
If you want to tighten it, maybe that's why you're having so much trouble removing it
The opposite.
Rich is offline
post #8 of 10 (permalink) Old 03-17-2016, 01:27 PM Thread Starter
Probably.
Ok, so I'm confused. Facing down at the top of the trem, I'd want to twist the holder counter-clockwise to remove it, and facing up at the bottom of the trem, from the back side, I want to go clockwise?
I owe you a beer either way, man, or whatever your drink of choice is, if we ever happen to meet some day, as a small token thank you for eveything I've learned on your site over the years.
Drew is offline
post #9 of 10 (permalink) Old 03-17-2016, 01:44 PM
Yes. Except forget about the top.
Bring a blunt.
Rich is offline
post #10 of 10 (permalink) Old 03-17-2016, 02:42 PM Thread Starter
No promises, but I'll see what I can do.
And yeah, I'm going to be operating from the underside, no need to risk scratching the face of the trem.
Drew is offline
EdgeZero arm-holder in reissued Edge/LoPro? nuno Comments to Ibanez 3 12-29-2009 11:10 AM
is the whammy 'arm holder' of a lopro exactly the same as on Edgepro? Ki swordsman Tech: Setup, Repairs and Mods 6 08-26-2007 12:30 AM
Help with tightening arm holder/removing trem... i'm scared! ddk Tech: Setup, Repairs and Mods 18 05-28-2004 12:12 AM
can i tighten the arm holder w/o removing the trem? caprile Tech: Setup, Repairs and Mods 16 07-26-2002 09:45 AM
Removing the tremolo arm holder - What's the best way hermit Tech: Setup, Repairs and Mods 5 02-03-2002 06:27 PM
