Replacement nut for my OLP? - Jemsite
post #1 of 8 (permalink) Old 02-21-2004, 10:06 AM Thread Starter
I preferably need a pre-cut nut for my OLP.
The width of the nut is 42mm, and fenders are 43mm, so was wondering if i'd have any problems if i installed a pre-cut fender nut onto it.
matt_cater is offline
post #2 of 8 (permalink) Old 02-21-2004, 12:24 PM
hey
Why don't you get one of the new Earvana nuts so you not only get a great nut, but your guitar is in tune the whole way across the board.
BCShredder is offline
post #3 of 8 (permalink) Old 02-21-2004, 01:50 PM
You'd have to match the radius, but also the string spacing. With a wider pre-cut nut your E strings could slip off the edge of the frets easier when you're playing, because they'll sit closer to the edge. Pre-cut doesn't really mean exactly that either. It's got grooves in it but they usually aren't angled on a strat style nut. You'll still have to cut them or have someone do it for you. If you just want a quickie, you still should look for a nut with the right string spacing.
frankfalbo is offline
post #4 of 8 (permalink) Old 02-21-2004, 02:58 PM
Re: Replacement nut for my OLP?
Matt, Look up machinehead.co.uk, Jeff will sort you out, If he can't he'll know someone that will ;-)
Rob
Jem7RB MK is offline
post #5 of 8 (permalink) Old 02-21-2004, 03:06 PM Thread Starter
thanks guy, especially rob
the reason i need a new nut is... when i was using heat to strip my headstock, i kinda melted the nut so it deformed lol.
i'll fire off an e-mail to machinehead now
post #6 of 8 (permalink) Old 02-21-2004, 03:23 PM
Actually i have a bundle of plastic nuts here, I'll go measure them and see if they are the same width ... If they are you can have one ;-)
Rob
post #7 of 8 (permalink) Old 02-21-2004, 03:26 PM
i have 42mm in cream new,and 44mm new in creme ... how typical, I have a beat and needs cleaning up Black 43mm nut of an epiphone tho ?
Rob
post #8 of 8 (permalink) Old 02-21-2004, 03:28 PM
Just re-read i have a 42mm in creme, PM me your address and i'll pop one off to ya ;-)
Rob
(shaking head for not reading properly)
strat style
Lo Trs replacement [email protected] Tech: Setup, Repairs and Mods 4 04-05-2011 03:47 PM
Possible Lo-TRS replacement? Ayrton Tech: Setup, Repairs and Mods 10 02-26-2007 09:41 PM
TRS replacement Sol player Tech: Setup, Repairs and Mods 3 04-04-2006 03:43 PM
Replacement for Lo-TRS? pedalinbob All Other Guitars (including Prestige) 2 01-18-2006 10:46 PM
Jem replacement ukwan Ibanez JEM, UV, JS & Other Signature Models 12 08-21-2004 12:15 PM
