Replacing a Lo-Pro Edge with a Floyd Rose using the old studs and inserts - Jemsite
post #1 of 1 (permalink) Old 03-27-2020, 06:11 AM Thread Starter
I have replaced a Lo-Pro Edge with a Floyd Rose on a RG550LTD. I didn't have a big nut to use the trick to remove the stud inert (hardware shops are closed in Bangkok) so I have used the old studs.
The studs are a little bit different (I forgot to take a side-by-side picture) but so far it seems to work OK. Stable and fluttering.
Do you think that the edges could be damaged when using with different studs?
BTW: I do not have any complain about the Lo-Pro Edge. This is the fourth time I replace it on this guitar, due to heavy use, and I have chosen the Lo Pro Edge only because one guy was selling it for a good price
edit: I am not going to miss the damn arm bushes. I like the arm to stay firm where I want
pingfloid is offline
floyd rose , inserts , lo-pro edge , replacement , studs
