Replacing Strings on Edge Pro - Jemsite
post #1 of 3 (permalink) Old 10-25-2004, 08:43 PM Thread Starter
Hey i am really new to the floyd rose bridge..my only guitar with the edge pro that i just got is the JS1000..my strings have become quite old and my E string has just broken and I really need to be walked through on how to replace the strings with this type of tremelo
GlassPrison2112 is offline
post #2 of 3 (permalink) Old 10-27-2004, 12:51 AM
with edge pros, you don't need to cut the ball end. With that said, lets go into the steps. First rule, change strings one by one. This will really speed up the process. So in your case, you broke the high E string, replace that first. Insert the ball end into the saddle, lock it, and get it in the tuning machine on the other end. Now tune up the string and move to the next one. Make sure you bring every string to tune so to maintain the floating position of your bridge. I think that was too breif but you should be able to do it. Good luck
bobojem is offline
post #3 of 3 (permalink) Old 10-27-2004, 02:53 AM
you don't have too, but it gets really old, really fast when you have to unscrew the slot a ton just to fit the ball end. I would say cut it off. As, for restringing...
http://www.jemsite.com/tech/t_rstrng.htm
that should help you out!
RSVampire is offline
edge pros , floyd rose , floyd rose bridge
Replacing Edge Zero II with Original Edge MatiasTolkki Tech: Setup, Repairs and Mods 15 10-09-2013 09:33 AM
Replacing Edge/LoPro Edge with a ZR tremolo? ZOMB13 Tech: Setup, Repairs and Mods 8 06-04-2009 01:00 PM
Replacing an Edge FX (fixed bridge) with an Edge Pro or OFR? twooos Tech: Setup, Repairs and Mods 13 10-28-2007 03:29 AM
Replacing an Edge FX (fixed bridge) with an Edge Pro or OFR? twooos Tech: Setup, Repairs and Mods 1 10-21-2007 08:06 PM
Replacing Lo-Pro Edge trems with original Edge? Max-T Tech: Setup, Repairs and Mods 1 09-06-2004 08:54 AM
