Restringing Help - Jemsite
post #1 of 6 (permalink) Old 01-16-2012, 05:41 PM Thread Starter
Restringing Help
This is probably a really stupid question, but I recently purchased an Ibanez RG 920. I was changing the strings and the G string snapped from the bridge, and now a little piece of string is now stuck under the string holder block. I tried to put another string on, and it wouldn't stay. I can't seem to get the little piece out. What should I do?
chrisrab5150 is offline
post #2 of 6 (permalink) Old 01-16-2012, 11:32 PM
Re: Restringing Help
I would assume you've tried flipping the guitar over and tapping gently, allowing gravity to sort things out?
Do you happen to have a strong magnet (for screw/metal parts retrieval) ?
A picture might help.
limbo is offline
post #3 of 6 (permalink) Old 01-17-2012, 01:35 AM
Maybe use a pen knife and scrape it off? That's assuming the piece of string is stuck because of the pressure from the string clamp causing it to stick to the bridge.
BlanK is offline
post #4 of 6 (permalink) Old 01-17-2012, 03:29 AM
Reviews: 59
Be careful and gentle no matter what. Leaving it or causing a scratch will lead to more strings breaking at that point.
hp29 is offline
post #5 of 6 (permalink) Old 01-17-2012, 04:41 AM
If the above shake and gravitate don't work, I can only suggest to disassemble the trem. It isn't too difficult. Don't lose parts, keep everything in the right place when you re-assemble
Ibateur is offline
post #6 of 6 (permalink) Old 01-24-2012, 03:37 PM
some times this happens too me if u have a ball end get a bigger string and try to push it out through the top Lol
dartvader is offline
rg920
Restringing cityofdelusion All Other Guitars (including Prestige) 62 05-15-2009 05:28 PM
Restringing at the Post klp2332 Tech: Setup, Repairs and Mods 5 01-19-2006 01:07 PM
Restringing Tips klp2332 Tech: Setup, Repairs and Mods 1 12-04-2005 09:55 AM
restringing problem mike2558 Tech: Setup, Repairs and Mods 3 09-22-2005 04:55 PM
Mal-restringing Vai the god of Sound Tech: Setup, Repairs and Mods 4 07-12-2002 09:56 PM
