Restringing at the Post - Jemsite
post #1 of 6 (permalink) Old 01-19-2006, 06:54 AM Thread Starter
Do you
1. Wound the string a few times on the post then put it through the hole.
2. Leave some slack and put it through the hole and then start to turn the machine heads.
Which one do you do? Which one is the correct way?
klp2332 is offline
post #2 of 6 (permalink) Old 01-19-2006, 09:15 AM
Re: Restringing at the Post
i do neither, i put the ballend at the post
timi_h is offline
post #3 of 6 (permalink) Old 01-19-2006, 09:26 AM Thread Starter
so you dont even wind at all... so you just put the string through the hole and then over the nut to the bridge?
klp2332 is offline
post #4 of 6 (permalink) Old 01-19-2006, 09:31 AM
JJEMMER777's Avatar
Originally Posted by klp2332
Do you
There is no correct way - as long as the final outcome is the same....do which ever way you prefer / works best / fastest for you
JJEMMER777 is offline
post #5 of 6 (permalink) Old 01-19-2006, 09:55 AM
With the ball end at the post, pass the string under the retaining bar and thru the nut, and cut it at the bridge, leaving a lil over 2 inches past the saddle... then lock the saddle screw and start winding the tuner till you get to the right note...
If it has old strings and its in tune, do one string at a time and it should be perfect when you do the last string...
marianozz is offline
post #6 of 6 (permalink) Old 01-19-2006, 01:07 PM
AND the ballend being tight to the tuner makes it as easy to restring and wind as with locking tuners
timi_h is offline
locking tuners , retaining bar
Restringing a EDge zero II macman70 All Other Guitars (including Prestige) 1 09-22-2012 04:57 AM
Restringing Help chrisrab5150 Tech: Setup, Repairs and Mods 5 01-24-2012 03:37 PM
Restringing cityofdelusion All Other Guitars (including Prestige) 62 05-15-2009 05:28 PM
restringing problem mike2558 Tech: Setup, Repairs and Mods 3 09-22-2005 04:55 PM
Mal-restringing Vai the god of Sound Tech: Setup, Repairs and Mods 4 07-12-2002 09:56 PM
