Rewiring a guitar - Jemsite
post #1 of 8 (permalink) Old 11-21-2005, 10:14 AM Thread Starter
Rewiring a guitar
I recently got a new guitar, and I was wondering how hard would it be; for someone like me who has never ever done something like that; to replace the pickups, change the volume pots to push/pull pots, switch the volume knobs to the pickups (i.e., I have a les paul copy and the volume knob on the bottom controls the bridge pickup and the volume knob on top controls the neck pickup, I want to swap those but keep the selector switch the same), and I think that's it.
I figured I'd need a soldering gun, solder, a voltmeter, and a wire stripper/cutter.
I'm thinking I need a plan of attack so I won't get overwhelmed and won't get in the way of myself.
So what are ya'lls opinions? I really want to learn to do this stuff, maybe I should buy a book on it? I was thinking I could stumble around and 'get it'.
Any advice would be greatly appreciated.
linthat22 is offline
post #2 of 8 (permalink) Old 11-22-2005, 11:49 AM
Re: Rewiring a guitar
I just recently had my first pickup change experience. It wasn't too bad. I wish I had bought one of those magnifying glasses with the alligator clip arms that hold wires in place for you. Basically, I had to teach myself how to solder. I read a few FAQs online about soldering, etc. and practiced a bit on some wires. I didn't get a good ground connection to the volume pot the first time and only 1 position on my switch worked but once I figured it out and soldered it a little cleaner it worked fine. I went back and re-soldered half of my connections once I got a good feel for it and was able to make cleaner looking connections.
In the end, it wasn't too bad, a little time consuming but I'll definitely do it again. Don't cut your wires too short and expect to have to redo a few things. Don't get frustrated, remember that it's your first time!
Good luck!
Allen
EvilEmuOfDoom is offline
post #3 of 8 (permalink) Old 11-22-2005, 12:08 PM
Reviews: 7
I've never had to use a volt meter for rewiring, but it's not hard at all. If your paranoid about it, make a wiring diagram of how your guitar is wired now so you can see where you made a mistake if your guitar doesn't work at first. Overall a 12 year old could do it with some direction, so there's nothing to fear.
brothersnowgone is offline
post #4 of 8 (permalink) Old 11-22-2005, 12:11 PM
I didn't use a volt meter either. Also, I used a 25watt soldering iron.
post #5 of 8 (permalink) Old 11-22-2005, 04:17 PM Thread Starter
I was told that a voltmeter would be good to use to check connections, but if ya'll think it's useless, that'll just save me some cash.
post #6 of 8 (permalink) Old 11-22-2005, 04:34 PM
bluealien's Avatar
Well I have use one in th past on a old guitar to ohm out the wires to see if the were still good... I guess you can also check if you have a cold solder joint, but as long as you prep the wires (put solder on a new wire before solder to switch or pot) you shoul d be fine. Its really not hard. if you havent solder befor just practie with some wire and sold the together... have fun
bluealien is offline
post #7 of 8 (permalink) Old 11-22-2005, 06:27 PM
I'm sure it could come in handy but if you don't already own one I wouldn't say you NEED it. You could always run out to get one real quick if you're having problems and decide you need it.
post #8 of 8 (permalink) Old 11-23-2005, 06:42 AM Thread Starter
ya'll are awesome as always, thank you for the encouragement and responses.
I take it that switching out the pots isn't really all that hard? from normal one's to push/pull?
bridge pickup , les paul , neck pickup , volume knobs , volume pots , wiring diagram
Rewiring entire guitar, new pups, 5way selector, pots, wire etc... Kirk Kirkwood Tech: Setup, Repairs and Mods 5 03-19-2012 05:01 AM
Rewiring RG bLYNDcYDE Pickups & wiring 1 05-02-2008 12:15 AM
Help with Rewiring my RG Optiquest Pickups & wiring 4 02-14-2005 08:03 PM
rewiring The Madness Here Tech: Setup, Repairs and Mods 0 08-20-2003 09:52 PM
Rewiring a Jem like a JPM lhrocker Pickups & wiring 1 05-28-2002 09:39 PM
