Rf shielding paint - Jemsite
post #1 of 19 (permalink) Old 02-02-2012, 05:54 PM Thread Starter
Rf shielding paint
Can anyone suggest a good brand of rf shielding paint and where to buy from. Looking on the web i can only find it in large amounts for around $90
hangingmonkey is offline
post #2 of 19 (permalink) Old 02-03-2012, 01:00 AM
Re: Rf shielding paint
Even with shipping from Germany, this might be your deal:
http://www.rockinger.com/index.php?c...&product=07300
13,90 Euros which should be something around 15 to 20 Dollars
Jemanized is offline
post #3 of 19 (permalink) Old 02-03-2012, 02:09 AM
it is relatively expensive stuff - most places will charge you a fair amount for applying it for you, due to the high cost of materials!
but a litre would last you for AGES!
rickybaby1985 is offline
post #4 of 19 (permalink) Old 02-03-2012, 04:17 AM
RGTFanatic's Avatar
RGTFanatic is offline
post #5 of 19 (permalink) Old 02-12-2012, 12:12 AM Thread Starter
Thanks guys!
post #6 of 19 (permalink) Old 02-12-2012, 09:54 AM Thread Starter
I found some going cheap on ebay but its about 30 mls. Any idea how far that would stretch? Is it enough to do 2 guitars?
post #7 of 19 (permalink) Old 02-12-2012, 12:36 PM
Is there a reason you want to use paint instead of foil?
gideond is offline
post #8 of 19 (permalink) Old 02-12-2012, 12:51 PM Thread Starter
Just seems easier than cutting out bits of foil and trying to cover the back and sides of the cavity
post #9 of 19 (permalink) Old 02-12-2012, 01:54 PM
I've done foil before and if I can do it so can you. Seems cheaper than paint as well. It is much like putting aluminum foil into a cavity... it just molds itself to the cavity.
chrisf is offline
post #10 of 19 (permalink) Old 02-12-2012, 06:33 PM Thread Starter
Im sure i can do it but i guess i was just looking for the lazy mans method.
Is one method more effective than the other?
post #11 of 19 (permalink) Old 02-13-2012, 06:59 AM
I think proper foil gets you a better shield job. Paint can be tricky. You need multiple coats to make sure your shielding is good. There is no way to tell for sure exact how well the metal particles are dispersed throughout the paint. Stir it, shake it, mix the crap out of it and hope for the best. On a side note, you can use aluminum duct tape from somewhere like Lowes to shield. It's cheaper than copper and works just as well so long as you don't have to solder anything to it. Solder doesn't like aluminum.
gideond is offline
post #12 of 19 (permalink) Old 02-13-2012, 12:56 PM
if you're only doing 2-3 guitars, foil. 30,000? paint.
BlanK is offline
post #13 of 19 (permalink) Old 02-13-2012, 02:52 PM
Aluminum tape, used in AC ducting. Works awesome, you can apply multiple layers quickly and easily... a small roll will cost $5-$7 and will last for multiple guitars. Also good for shielding on the back of a pickguard or apply to the control cavity covers on the back.
Bluestreak is offline
post #14 of 19 (permalink) Old 02-13-2012, 03:49 PM
Foil is actually easier than paint.
The paint is thick, messy, dries slowly and takes many coats to be effective. And even then I do not believe it produces a better cage than copper foil at all. The shielding paint just does a poor job, and it breaks down over time rather quickly.
The foil on the other hand is clean, very effective and nearly fool proof. Add in the fact that it is faster by about a factor of six and there is really no choice between the two. Even if the adhesive fails after years you are still left with a fully functioning faraday cage, something that can not be said for the paint.
It also costs about 4xs more in materials to shield with the inferior paint.
musikron is offline
post #15 of 19 (permalink) Old 02-13-2012, 04:26 PM Thread Starter
Thanks for the advice guys. Sounds like foil would be the better option. Ive never used foil before. Do i need to add a drop of solder between each of the strips to make sure that all the pieces conduct to ground?
paint , shielding
Shielding paint ground Devon8822 Pickups & wiring 2 04-18-2010 08:57 PM
FS: RG1570 Prestige Body with Sustainer Routing and Shielding Paint For_The_Love_Of_Jems Classified Ads: Guitars and Gear 3 11-19-2008 03:38 PM
Pickguard shielding - aluminium or copper foil, or paint? axemanrio Pickups & wiring 6 05-24-2008 08:43 PM
What about shielding? [email protected] Pickups & wiring 2 08-10-2006 07:11 PM
Shielding with paint or copper foil? guitarkatana Pickups & wiring 9 12-31-2003 06:56 PM
