Is RG 1527 body made up of laminated bass wood? - Jemsite
post #1 of 13 (permalink) Old 04-07-2004, 01:21 PM Thread Starter
From my observation, I concluded that it is. If I am wrong, let me know.
jemsmyuniverse is offline
post #2 of 13 (permalink) Old 04-07-2004, 03:04 PM
And you observed this with your Xray spy glasses found in this mornings Captain Crunch box?
Rich is offline
post #3 of 13 (permalink) Old 04-07-2004, 05:19 PM
RG1527
I guess some people never grow out of childhood memories. But who cares? Many people here like you and even buy guitars from you.
I also discovered several layers of wood sandwitched on top. It was visible from tone/volume pot holes.
philzeta is offline
post #4 of 13 (permalink) Old 04-07-2004, 05:33 PM
Not me, I'm a Frosted Flakes guy
Well that actually makes no sense. I've got a couple 1527's comming I'll definately have to pull a pot on, but, still makes no sense.
Rich is offline
post #5 of 13 (permalink) Old 04-07-2004, 05:36 PM
site founder 0% owner
jemsite's Avatar
look in the trem cavity or electronics cavity. it should not be laminated, as that would be absurd... glen
jemsite is offline
post #6 of 13 (permalink) Old 04-07-2004, 05:49 PM
Very few mass-produced guitar bodies are one piece of wood, simply because 18" to 24" wide planks of instrument-quality lumber are relatively uncommon (and expensive).
It's not at all uncommon for a solid body to be made up of two or three pieces laminated together, in order to get a piece of lumber wide enough to cut a body from. On guitars with transparent finishes, they often try to make the body from two (sometimes three) pieces of wood. On guitars with solid finishes, it's not unusual to have three or more pieces of wood laminated together.
darren wilson is offline
post #7 of 13 (permalink) Old 04-07-2004, 05:52 PM
jemsite's Avatar
jems have traditionally been 2 piece bodies which is a classic design. MIJ RGs were the same. There were pics of the DBK bodies that looked like 6-piece. Either way these are no "laminated" which implies several layers (top to bottom). glen
jemsite is offline
post #8 of 13 (permalink) Old 04-07-2004, 08:52 PM
You can't, it's painted
Rich is offline
post #9 of 13 (permalink) Old 04-07-2004, 08:57 PM
Re: Is RG 1527 body made up of laminated bass wood?
So what exactly did you observe that led you to this conclusion?
post #10 of 13 (permalink) Old 04-07-2004, 09:36 PM
jemsite's Avatar
i know, but you should be able to feel/see the (absence of) lamination seems on the large surface ... glen
jemsite is offline
post #11 of 13 (permalink) Old 04-07-2004, 10:18 PM
Wouldn't the neck pocket also be a good place to check? Or does Ibanez paint those, too?
post #12 of 13 (permalink) Old 04-07-2004, 10:19 PM
jemsite's Avatar
those are unpainted if you wanna remove the neck ... glen
jemsite is offline
post #13 of 13 (permalink) Old 04-08-2004, 07:19 PM
it is very common that guitar bodies are made from several blocks of wood ~4-8" wide glued together on the edges. most bodies are at least two pieces, and some can be as many as 4, like my RG2027. the 1527 body is almost certainly at least two pieces of edge joined wood, and possibly 3 or 4.
"laminated" refers to flat layers [i.e. 'lamellar,' etc.], like plywood, not edge-joined blocks of solid wood. only really cheap guitars will use plywood for a body -- even the recent Squiers are made with solid agathis rather than plywood.
there's no way a mid-high end RG is made of plywood. you might be seeing the edges of router cuts or coats of shielding paint that can look like a layer in the wood underneath.
Wich wood is this guitar's body made of? Powernico Forum Announcements and Member Help 3 04-13-2012 03:10 PM
Wich wood is this guitar's body made of? Powernico All Other Guitars (including Prestige) 21 01-05-2012 02:50 PM
Has anyone gone to a wood workshop with design+wood and gotten a CNC'd body? Ki swordsman Tech: Setup, Repairs and Mods 13 06-30-2007 12:33 PM
Cazares body wood. - What's his toy made of? keith All Other Guitars (including Prestige) 13 03-25-2002 09:40 AM
Wood types for a universe body? - What wood type has a thick FORTHELOVEOFSWIRL Gear, Equipment, Recording & Off Topic 3 09-08-2001 08:17 AM
