RG 550 Neck Fit - Jemsite
post #1 of 8 (permalink) Old 11-24-2003, 03:05 PM Thread Starter
RG 550 Neck Fit
I just got an RG550 neck, its stamped RG550R#2 on the heel.
I have a body I bought about a year ago, its a 2002 RG550 body.
They don't fit together
I suppose it may be a wizard 2 profile neck, but it says made in Japan on the back of the headstock, and I thought wizard 2 was only on cheap korean models.
If this problem isn't just my imagination, please give me a shout. Is it possible to retrofit this neck onto my body if it is the wizard 2?
shredmaster26 is offline
post #2 of 8 (permalink) Old 11-24-2003, 03:47 PM
See here:
http://jemsite.com/axes/htm_features/neckjoint.htm
Just look at the screw pattern and that will give you your answer.
The 02 550 has the AANJ (All Access Neck Joint) while your neck may have the original joint.
I would see about selling the Orig and buy an AANJ neck.
Much easier than messing up a good neck.
Bamm
bammbamm is offline
post #3 of 8 (permalink) Old 11-24-2003, 03:57 PM
If they both are AANJ and you just can't press the neck in because the wood is swollen or the pocket is too narrow, that's common. There are tolerances between them so that some necks will be loose in other bodies and vice versa. If the neck has a nice finish on it I would dremel/sand/scrape, whatever from the neck pocket. If the neck is beat up, and you plan to strip it and oil it, or refinish it, you can sand a little away from the sides of the neck.
But if the neck joints are different, bamm is right, don't bother.
frankfalbo is offline
post #4 of 8 (permalink) Old 11-24-2003, 03:59 PM Thread Starter
No, no, I definitely know the difference between an aanj and a square heel, I own a 777DY. This neck is aanj. It says made in japan, and although I previoiusly believed it to be otherwise, I'm beginning to think that it is a wizard 2. What else would expain a made in Japan RG550 neck not fitting a made in japan RG550 body?
post #5 of 8 (permalink) Old 11-24-2003, 04:02 PM Thread Starter
Ah, I see. I guess I could ask my uncle who builds guitars to help me with this, he's built a lot of guitars and probably thinks this is no problem. But has anyone here had to do this sort of thing to get a neck to fit? If you did, what did you do?
post #6 of 8 (permalink) Old 11-24-2003, 04:05 PM Thread Starter
damn- double post
post #7 of 8 (permalink) Old 11-24-2003, 04:14 PM
Yeah, all the time. I have like 15-20 Ibanez and I'm always jacking around with neck swaps. Few are stock and I buy necks on e-bay sometimes, too. There's always some fitting differences, and on some guitars, it's caused me not to make the switch, because I realize I'd have to do too much.
Most of the time, I will re-route the neck pocket anyway, because I like to recess it, and put a little neck angle in it. That way the neck sits a little lower and the bridge is the same or higher, giving more pullup. Most of my older Ibanez guitars had neck shims in there from the factory. So I pull the shim and route an angle right into the pocket. If I'm doing that, I'll use the router to widen the pocket if necessary. If not, then sometimes I'll use a dremel, a file, a sanding block, a razor blade, or whatever.
An RG neck pocket is deep enough, so you can just widen the slot. You should take an equal amount off each side, but sometimes one side is clearly the main offender. You're really not going to know which side. You have to check the alignment, and the screw locations vs. the holes. I would take equal amounts off until it goes in. If you do it with a router only, be careful for chips around the edge. I will almost always do the "entry" areas by hand.
post #8 of 8 (permalink) Old 11-24-2003, 04:21 PM Thread Starter
Thanks frank, I feel a lot better now. I just checked again, and you're right- the heel is barely larger than the pocket at all. I'll probably get my uncle to read your post and help me out, I'm too afraid to go in there wielding a dremel tool myself- both parts are in great condition.
aanj neck , access neck joint , ibanez guitars , neck angle , neck joint , neck joints , neck shim
Richie Kotzen's Electric Joy neck pickup, Ibz RBM pickguard & 1966 Fender Neck Plate mayzan Classified Ads: Guitars and Gear 0 11-30-2010 10:04 AM
FS: RG550 Maple neck/Edge Trem, Jackson neck, Dimarzio pups NickCormier Classified Ads: Guitars and Gear 10 01-08-2010 12:46 PM
Flamed jackson neck, birdseye musikraft neck, loaded strat body shesky Classified Ads: Guitars and Gear 2 04-30-2009 06:02 PM
SWAP: Jem neck 77FP tree of life and floral head for 777DY pyramid neck blitzmark1 Classified Ads: Guitars and Gear 2 03-19-2009 06:41 PM
ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only) 7-request Pickups & wiring 2 07-05-2005 11:18 AM
