RG 550 RFR Edge Bridge question - Jemsite
post #1 of 6 (permalink) Old 09-19-2015, 11:45 PM Thread Starter
Dear fellow jemsiters,
I have my RG 550 RFR for close to a year now and have noticed that the whammy bar getting 'looser' (despite having no 'play' whatsoever) it doesn't just sit on one position anymore like when it's new. Well since it's a 'push' in whammy unlike the floyd rose, my question is how can I just slightly tighten the whammy just so that it doesn't 'swivel' freely but just snug and doesn't move around?
Any 'Ibanez' approved methods to tighten this thing just a slight weeny bit?
Atomant is offline
post #2 of 6 (permalink) Old 09-20-2015, 07:07 AM
Re: RG 550 RFR Edge Bridge question
Try replacing the white plastic rings on the whammy bar. Also, just to check, open the backplate and check if the screw holding the little pin spring at the base of the trem socket is still tight.
The RG550 RFR 1987 was my first Ibanez :-)
GoodVaibes is offline
post #3 of 6 (permalink) Old 09-20-2015, 11:07 PM Thread Starter
Thanks GoofVaibes, any source or links I can get a hold of those plastic rings from?
I first saw the 550 some 28 years ago. Right after purchasing my first Ibanez S540 then did I know I made the wrong choice!
Now after 28 years of not playing the guitar I have finally gotten the 'standard' Ibanez. The RG 550 and the S540 was so much 'wow' back then and still is today in my eyes.
Atomant is offline
post #4 of 6 (permalink) Old 09-21-2015, 07:38 AM
You can get those teflon bushings here: http://ibanezrules.com/
If you get some of those and replace them make you put the new ones on correctly. There are three dots on one edge of them; those face down or towards the pointy end of the bar.
You can also get some plumbers tape and put 1 or 2 layers inside the groove before putting the worn bushing back in place.
I like to use a cut strip from a ziplock bag just wide enough for the bar's groove as this lasts a bit longer, but the bushing has to be quite worn for this to work. Cut the strip long enough so you can hang on to the loose ends while it wraps the groove and put the worn bushing on, then cut the excess with scissors.
My favorite solution the Ultralite Tremolo Arm (UTA20) arm though. Greatest whammy bar ever! While the bushings still wear out with one of these, it takes a lot longer.
mjstack is offline
post #5 of 6 (permalink) Old 09-21-2015, 11:59 PM Thread Starter
Hi mjstack, thanks for a whole bunch of tips.
Seems like there is no surefire solution for the whammy bar issue.
This would take me awhile to figure out what works for me!
I've had my fair share of problems with the floyd rose too. But still love my floating bridges n not going anywhere without it.
Atomant is offline
post #6 of 6 (permalink) Old 09-22-2015, 11:21 AM
I take the bar off and replace it with a Floyd rose type screw on collar. It's completely reversible and works great.
Pewtershmit is offline
bridge , edge , tremolo , whammy
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
LF: Ibanez Edge or Lo Pro Edge bridge in Cosmo Black supergirl20_06 Classified Ads: Guitars and Gear 0 09-19-2010 10:02 AM
Quick question - can i fit the edge bridge on a new JS1000? lonewolf Ibanez JEM, UV, JS & Other Signature Models 2 12-04-2008 11:09 AM
Bridge Knife Edge Question tt0511 Ibanez JEM, UV, JS & Other Signature Models 5 05-04-2007 11:24 PM
Question about the edge pro bridge on higher end Ibanez elpingua All Other Guitars (including Prestige) 3 11-19-2005 09:20 AM
