RG tremelo problems - Jemsite
post #1 of 7 (permalink) Old 01-21-2006, 06:28 AM Thread Starter
RG tremelo problems
I have an edge III on my RG.
Today, I increased the angle of the trem, tightened the truss rod.
When I press all the way down the bar at least two strings stay sharp UNTIL i unlock the nut. usually high E and B.
God BLess
Ian
FireAndSpirit is offline
post #2 of 7 (permalink) Old 01-21-2006, 06:30 AM
Re: RG tremelo problems
Could this be an intonation problem? Just wanted to know.
amanvai is offline
post #3 of 7 (permalink) Old 01-21-2006, 07:47 AM
Why did you increase the trem angle? Was it wrong or did change string thicknesses?
Regards
André
fettouhi is offline
post #4 of 7 (permalink) Old 01-21-2006, 08:01 AM
Trem angle should be parallel to the body, or at right angles to the trem posts.
Check out Ibanezrules tech section to check you've got the truss rod, action and trem set right
markg5150 is offline
post #5 of 7 (permalink) Old 01-22-2006, 04:06 AM Thread Starter
I don't really know how to explain it... I thought that I was actually making the tremelo angle more perpendicular...
See, the problem is, the floyd that I have DOESN'T have a rectangle, so it's difficult for me to see what is what and who is who.
It's an edge III. For some reason whenever I depress (subsantially), the thing goes like way out of tune. The high E string goes a bit sharp... stuff like that.
But here's the thing, if I pull up on the string with my fingers around the 12th fret it goes back in tune...
OR, if I loosen the nut, it goes back in tune... I don't know... I didn't start having this problem until YESTERDAY when I did a setup on it. before it stayed in tune well.
UG!!!!
Ian
post #6 of 7 (permalink) Old 01-22-2006, 06:19 AM
UG!!!!
Ian
Have you read the tech section at ibanezrules.com (banner above)?
Regards
André
fettouhi is offline
post #7 of 7 (permalink) Old 01-22-2006, 11:10 AM
Unclamp all the strings at the nut, flip the neck over unscrew the two bolts that hold the locking nut to the neck of the guitar just a little to allow movement of the nut, push the nut towards the fingerboard, when it is tight against the fingerboard, thghten the bolts that hold on the nut, it sonds like the locking nut is loose and is moving when you use the trem, it is general maintenance that should be done every so often as these bolts come loose, if this does not fix it, have a look at the nut itself, are there grooves in it where the strings run over the nut?, if there are you will need a new nut, as these can cause the string to slip, and give you weird tuning problems.
Eddy
Eddy_mc is offline
locking nut , truss rod
Jem Tremelo Help XD Verus Gear, Equipment, Recording & Off Topic 10 07-22-2009 10:18 PM
wtb: lo pro tremelo IanRG7421XL Classified Ads: Guitars and Gear 1 08-29-2006 09:08 AM
Lo-Pro Tremelo Arm Walls1441 Tech: Setup, Repairs and Mods 1 07-27-2006 09:58 PM
Rg 3120 Problems. ANNOYING PROBLEMS!!!! Given to Fly All Other Guitars (including Prestige) 20 05-24-2003 01:24 PM
Please help: the tremelo on my Jem is all the way down satch1000 Tech: Setup, Repairs and Mods 3 05-11-2003 05:53 PM
