RG20th RFR major fret buzz issues - Jemsite
post #1 of 11 (permalink) Old 05-01-2013, 11:39 AM Thread Starter
I've owned my RG20th RFR from new and never had any problems with it. The guitar has always had a super low action and very flat neck and played perfectly, for my personal taste. I recently got some new strings, the same strings I've used for many years (D'addario EXL120) and the playability of the guitar has completely changed. There is fret buzz pretty much everywhere on the neck, worse on the lower strings and pretty much every fret above the 12th fret is dead / chokes out, again, worse on the lower strings. I've played guitar for 30 + years and have never been afraid to to my own repairs and set-ups etc and I actually did an apprentice luthier course 22 years ago. I've tried giving the neck some relief, although I do prefer a flat neck but I figured this might be the best option. The neck now has some relief, which in turn has given me a higher action, again not to my preferences as I prefer a super low action, and the fret buzz has still not improved whatsoever. Tried raising the action with the bridge studs to a ridiculous height and still it buzzes like crazy. Just can't for the life of me work out what has happened. As I say, it used to play perfectly, with a super low action and flat neck and now it plays like crap and buzzes and chokes, even with an action so high you would need a step ladder to play it. Any advice would be very much appreciated.
Thanks in advance
RGR570 is offline
post #2 of 11 (permalink) Old 05-01-2013, 11:49 AM
Demogorgos's Avatar
Red face Re: RG20th RFR major fret buzz issues
I also always do my own guitar teching, but this sounds really funny. When I'm lost, I have a friend who is a 30+ years pro guitar/gear dealer and have him take a look at it. Now that's what I'd do in your case, let somebody who is more knowledgeable than myself take a look at it and, as an added bonus, learn something new...
Regards,
JP
Demogorgos is offline
post #3 of 11 (permalink) Old 05-01-2013, 11:54 AM Thread Starter
Regards,
JP
Thanks for replying mate . If I was back home living in England, that's exactly what I would be doing. I'm currently somewhere where there's not many guitar techs, unfortunatley.
RGR570 is offline
post #4 of 11 (permalink) Old 05-01-2013, 12:15 PM
Demogorgos's Avatar
Thumbs up Re: RG20th RFR major fret buzz issues
We have some amazing craftsmen and builders on the forum, I suspect that you will get some more, useful, input along the day.
It could be an environmental thing, as the humidity is very high on the Canary Islands...
Regards,
JP
post #5 of 11 (permalink) Old 05-01-2013, 12:35 PM Thread Starter
Regards,
JP
Cheers mate. I did think that about the climate etc but I've lived here over a year and it only really happened the other week once I'd changed the strings. It's all a bit odd and very frustrating.
RGR570 is offline
post #6 of 11 (permalink) Old 05-01-2013, 06:31 PM
Reviews: 120
Do you perhaps need a fret dress now, after playing it for several years?
LonePhantom is offline
post #7 of 11 (permalink) Old 05-01-2013, 06:42 PM
Reviews: 37
check pickup height.
check trem angle.
sounds like something came loose when you changed strings.
last thing
did you cut all strings off at same time under tension?
id check the neck pickup height and go from there.
andrewsfury is offline
post #8 of 11 (permalink) Old 05-01-2013, 06:56 PM Thread Starter
Many thanks for the replies.
Frets are still in very good condition. Like I say, it played perfectly up until a couple of weeks ago.
Pickup height is the same as when I first set it years ago. Already experimented with lowering the pickups and no change whatsoever. The middle single coil is practically flush with the pickguard and the bridge and neck pickups are not excessively high.
Bridge angle is perfectly parallel, the same as all the other Edge / Lo Pro Edge Ibanez guitars I have / have had.
Strings were changed one at a time, nothing unusual.
Totally stumped here.
RGR570 is offline
post #9 of 11 (permalink) Old 05-01-2013, 07:22 PM
Reviews: 37
sucks.
change strings and call me in the morning, lol.
is the nut tight?
post #10 of 11 (permalink) Old 05-01-2013, 07:23 PM
metalhead52's Avatar
Sometimes you can get a bad pack of strings. Put on a new set and see what happens.
metalhead52 is offline
post #11 of 11 (permalink) Old 05-01-2013, 11:55 PM
Reviews: 11
Dummy checklist
-> tighten neck bolts
-> tighten nut bolts (dont over tighten obviously)
-> make sure studs are locked
-> change the strings again, may have gotten a dud. If you change strings and it fixes it, CONTACT ME, I can assist you.
-> since you can measure relief, you can verify the neck isnt warped as well.
Barring fret work, which isnt likely, I have no ideas what would cause extreme action change other then something coming loose.
linuxpenguin is offline
Fret Buzz Issues Ikeruga Tech: Setup, Repairs and Mods 3 02-06-2012 12:20 PM
MAJOR fret buzz!!! \Dom/ Tech: Setup, Repairs and Mods 38 01-26-2012 01:50 PM
Fret Buzz and Intonation Issues ANT5150 Tech: Setup, Repairs and Mods 3 09-23-2010 02:34 PM
RGT320 Fret buzz Issues - please help Jman76 Tech: Setup, Repairs and Mods 3 12-13-2009 12:27 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
